denso iridium ik24
Old Jan 4, 2006 | 06:51 PM
xviper's Avatar
yeah i only have about 4500 miles on my car. before i went FI. so i should be good for a few years xviper?
You "should" be but make sure they are gapped narrower for FI and it's good practice to pull them every few months and "read" them to see how your engine is doing. You don't want to find out that you're running too lean.
Any idea what plug is best for a NA s2k with typical bolt ons (intake, catback)
Nothing wrong with the stock platinum plugs for this application although some have reported slightly better performance from the Iridium plugs.
Old Jan 11, 2006 | 06:42 AM
ayS's Avatar
ayS
i just e-mailed comptech and they said the spark plugs come pregapped. and not to mess with it anymore or else you can mess up the electrode.
Old Jan 11, 2006 | 07:14 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
Just check the gap to be sure it wasn't dropped.
I'm a firm believer of OEM plugs for NA.
Old Jan 11, 2006 | 07:20 AM
ayS's Avatar
ayS
"dropped" meaning literally? also, does this apply if you are FI?
i don't know if i have failed spark plugs or could be something else but i started noticing 2 days ago, between 4-8k rpm range (ap2) that when i let off the throttle i hear something that goes something like "vvvvrrrrmmmmmvvvvrrmmmm" when i think the engine should be winding down smoothly like "vrrrrrrrrrrmmmm" to quiet. if that makes anything sense at all.
Old Jan 11, 2006 | 08:54 AM
xviper's Avatar
They all come "pre-gapped". That doesn't mean they will be the correct gap when you get them for your particular application. You don't actually think that the spark plugs you get were ONLY meant for your car, for your application, do you?
"Mess up the electrode". They have to target this to the lowest common denominator - the biggest cluts there are in the world, the ones who will, without a doubt, mess up the electrode. Thus, they tell you don't do anything to it. It's better sometimes to run the wrong gap than to run a plug that doesn't work at all.
ALWAYS check the gap. If they're correct, then fine. However, if one is wrong, then what are you going to do? Leave it alone and put it in anyway?
Old Jan 11, 2006 | 08:58 AM
xviper's Avatar
Bad spark plugs will show themselves on acceleration and coasting, not decelerating between a set rpm range. Since your injectors shut off on deceleration, your plugs aren't doing anything anyway. You're most like changing spark plugs for nothing.
Old Jan 11, 2006 | 02:00 PM
WyattH's Avatar
You said that iridium sparks might be okay for an NA application... Would these iridium sparks be IK22 still or IK24 as well? If one was putting down 235+ whp NA (raised compression, ported/polished head, EMS, etc.), what plugs would you recommend? And what gap?
Xviper - you da man!!!!!
Old Jan 11, 2006 | 02:51 PM
xviper's Avatar
You should attempt to use the coldest heat range of plugs that the engine will handle without fouling. In the case of an NA S2000 engine, many people have been using IK-24 (one heat range colder) in completely stock configurations without incident.
Insofar as "raised compression", I don't believe this alone on a NA engine would have the same problems as a F.I. engine in terms of blowing out the spark. I would go with IK-24 and a 0.040" gap to start with. After a couple thousand miles, take them out and see what they look like. This, more than anything, will tell you far more than to try and guess what might be best to begin with. From the condition of the plugs at that time, you can decide to go another step colder. A high rpm miss might be an indicator that you need to close the gap a bit more.
Old Jan 11, 2006 | 04:28 PM
WyattH's Avatar
Thanks a lot. Looks like I wont be selling my IK24s that were bought for my SC plan!
Old Jan 11, 2006 | 04:40 PM
xviper's Avatar
If you go S/C, you might not want to use them:
HOWEVER, there is a thread here where many F.I. owners using the Denso Iridium IK-24s, have had plug failures (myself included). Use them for NA, but you might want to reconsider if you are blown.
