destroking and engine
Old Dec 23, 2002 | 04:11 AM
Wisconsin S2k's Avatar
if you have a 1.6 liter engine and you want to destroke it to a 1.5 liter, can you do this by simply changing the rods? or must you also change the crank in order to keep the same compression? i didn't think it was necessary to change the crank..... ???
Old Dec 23, 2002 | 04:12 AM
oops.... meant to put this in "under the hood" forum. if any mod wants to move it feel free
Old Dec 23, 2002 | 06:13 AM
Default destroking an engine
When you destroke an engine, what all does this entail? If you change the crank so your stroke is shorter, how do you keep compression? I was told longer rods was an answer or taller pistons?
Old Dec 23, 2002 | 07:11 AM
phaco's Avatar
Must change the crank. Also, must change rods and/or change piston pin height to maintain the same geometry in the combustion chamber.
Old Dec 23, 2002 | 07:37 AM
xviper's Avatar
By changing only the piston rod and not the crank, the "stroke" will be the same amount of travel. All you'd be doing is increasing the amount of volume above the piston at the top of it's travel by shortening the rod. I suppose this might be a good way of making this engine a "non-interference" one.
Old Dec 23, 2002 | 08:06 AM
ultimate lurker's Avatar
Yes, usually the rods are longer. But the dome of the piston needs to be higher as well since you have less overall displacement and the same combustion chamber size.
UL
Old Dec 23, 2002 | 09:16 AM
ok. i was right then about my thoughts. thanks for helping me out!!!!!!!
Old Dec 23, 2002 | 09:18 AM
thanks UL.
So what, then, is the purpose of destroking an engine? To be able to rev higher??
Old Dec 23, 2002 | 09:29 AM
Strike's Avatar
Moving to UTH
Old Dec 25, 2002 | 12:10 PM
Incubus's Avatar
and what is "non-interface"?
I want to know.
