Did a compression test, not sure if I did it right
Old Dec 16, 2007 | 09:04 PM
1FastS2k's Avatar
Default Did a compression test, not sure if I did it right
So I've been having some misfire issues and after whacking the map sensor and checking the plugs it was still missing. I did a compression test but honestly I'm not sure if I did it right. Does this sound right?
1. Pulled all plugs
2. Pulled fuel fuse
3. Threaded tester into cyl closest to front
4. Cranked motor until gauge stopped moving
5. Repeated other cyls.
Was this the correct way? My # came up a little higher than I've seen posted up here.
cyl 1 (closest to front of car) was 235
cyl 2 was 225
cyl 3 was 225
cyl 3 was 235
Do these # seem too high or did I just not do it right?
Old Dec 16, 2007 | 11:16 PM
jyeung528's Avatar
i wouldn't complain if it was high.
i'd be a little concerned about the 10 psi discrepancy...but i don't thing that is a sign of your problems with the misfire.
Old Dec 17, 2007 | 07:19 AM
1FastS2k's Avatar
Thanks for the input. I thought that anything under 10% difference between the cyls was ok? After reading Random1's post, I'm thinking that it might be injectors. I'm on the road alot and haven't always been able to use the best gas and maybe that has started to take its toll.
Old Dec 17, 2007 | 08:20 AM
clawhammer's Avatar
I believe you did the compression test correctly.
Keep in mind that every gauge will read slightly different. What kind of gauge was it? Especially if it was a cheap one, I wouldn't worry about it. The compression numbers look pretty good.
Old Dec 17, 2007 | 08:39 AM
Silver9k's Avatar
Numbers look great, I wouldn't be worried about the numbers. And DEFINITLY NOT worried about the 10psi difference. That is entirely fine, especially at 160k miles. I'd say your motor is running very strong.
Another common thing to cause a misfire is a clogged cat. It will build up back pressure in the exhaust system and cause misfires. Its very possible that this is all you have.
Old Dec 17, 2007 | 08:44 AM
street_ruler's Avatar
you did it wrong actuially...
you should do this...
1 pull the fuel fuse,
2 start the car (or try to) and bleed out all the fuel pressure in the lines (which is why #1 was high)
3 remove one plug at a time (its easier to "count cranks" cause the motor wont just spin free)
4 install compression tester
5 hold the torottle wide open with clutch enguaged, wheel chock and an open area to run incase something catastrophic happens,
crank the motor a designated number of times (if you can get a clean count of like 9 or 10 or wahtever just crank it for a minute untill the gauge stops clmbing)
6 read and write down compression,
7 pour a rollop of oil down the sparkplug hole and retest that cylinder
8 record numbers and compare.
9 repeat for all cylinders.
EDIT: sorryt i read a little of your post wrong,
the middle two cylanders are normally lower because they have another cylinder on either side of them, they tend to wear out first just due to heat and what not. thats normal,
i would look to ahve a valve adjustment done and then retest. that difference of 10psi just looks like a valve lash adjustment is needed.
a higher "wet" compression test just means that your ruings are sealing better due to the oil. if there is a drastic change in numbers (more than about 25psi) then start looking at your rungs and ahve a leak down check performed. if ponly a small change (5-10) you;re fine.
a variance of 10PSI is nothing. id start worrying about a 20-35 change.
and like i said, it was because you ahd a little fuel in that cylander from not running the car without the fuel pump fuse removed
enjoy
Old Dec 17, 2007 | 08:47 AM
Silver9k's Avatar
enjoy
I was taught to always pull all the spark plugs, this way if there is a headgasket problem between two cylinders it is likely to show up in a compression test, however. If you don't have the adjacent spark plug removed it is possible for the other cylinder to hold the compression thus giving a false reading.
Old Dec 17, 2007 | 09:26 AM
1FastS2k's Avatar
Whether to remove all plugs or not is what I was confused about. I pulled all 4 then checked. I bought my compression tester from Harbor Freight tools so it's probably not the most accurate piece of equipment. I have yet to do a valve adj on this car and I think that this also might be contributing to the problem.
Old Dec 17, 2007 | 09:50 AM
yah its just easier with only 1 plug out.
and as for accuracy, it doesnt really matter if you ahve a 100,000 dollar gauge or a 10 buck gauge. its all about what that gauge reads. id say the gauge is not the problem
Old Dec 17, 2007 | 09:52 AM
[QUOTE=Silver9k,Dec 17 2007, 09:47 AM] I was taught to always pull all the spark plugs, this way if there is a headgasket problem between two cylinders it is likely to show up in a compression test, however.
