dif problem
Old Jun 7, 2013 | 05:19 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
Default dif problem
Thought you guys might enjoy this, came in on the flatbed yesterday. Says he was just driving along.
Maybe puddydad can fix
Old Jun 7, 2013 | 06:02 PM
CoolGuy094's Avatar
Well there's your problem!
Old Jun 7, 2013 | 06:03 PM
Murphg05's Avatar
Looks fine to me!
Old Jun 7, 2013 | 06:08 PM
joes sled 2000's Avatar
Just driving along ?
Old Jun 7, 2013 | 06:26 PM
s2000maniac's Avatar
lol is the car herrrafrushed?
Old Jun 7, 2013 | 08:15 PM
darcyw's Avatar
may have been driving along, but driving along and hit large inanimate object like a speed bump or tractor trailer tire. OUCH!
Sure makes the dif fluid change easier.
darcy
Old Jun 7, 2013 | 08:16 PM
CoolGuy094's Avatar
Its hellaf#*%ed now. Lol.
Old Jun 7, 2013 | 09:47 PM
xviper's Avatar
JB Weld ......... good as new.
Old Jun 7, 2013 | 10:58 PM
SpitfireS's Avatar
The left torsen bearing is split (you can see the rollers) and so is the cap.
AFAIK: signs of insantly messed-up pinion / ring contact.
If the pinion or ring teeth don't break-off, something else has to give.
In this case the ring went out the back.
Can you still turn the pinion?
Who did the last diff oil change?
(and used CRV diff "oil"..)
Old Jun 8, 2013 | 03:37 AM
Billman250's Avatar
Top Answer: 1
Not sure the fluid history, new customer.
Says he was beating on it days before, but when this happened he was at an intersection driving normal.
Pinion was free.
I'm guessing this is from high rpm clutch dumps from a dead stop.
