Diff Crush Washers
So, my local dealer doesn't stock the washers (gaskets) for the rear diff...
I was planning on taking care of it this weekend, but that isn't gonna happen. What's worse, is they charge like $3 for one, and $5 for the other :\
I see them online cheaper.
I found an OLD thread that linked this site: https://www.pegasusautoracing.com/pr...p?Product=3241
But I'm not sure which washers are the ones I'd need...?
I know the part numbers, but not the sizes...
You can definitely use the fill bolt washer several times over, the previous owner of my car used the same washer for 9 years. The drain bolt washer could be re-used once without issue if you are in a bind, just flip it over.
That's what I was thinking too, but I just bought it this past weekend, and the previous owner didn't know when it was last done... or who did it...
So, I wanted to do everything 100% so I know when everything was done last.
I've forgotten to buy them before, and had to reuse old ones. I've gotten away with just re-using one without doing anything, but there could be a small risk of leaking. If you want to go OCD about it, you can hold it to a propane torch until its beginning to glow, annealing it in seconds. Now it'll be soft again and deform easily when you reuse it! Bonus OCD points if you sand/file it flat before putting it on.
Yeah, I've reused them a few times too, but I just bought this car a week ago, and want to do everything new so I know.
Previous owner doesn't know that info.
I ended up finding the washers at a dealer about 30 minutes away. Gonna roll out there tomorrow and get a few
Previous owner doesn't know that info. I ended up finding the washers at a dealer about 30 minutes away. Gonna roll out there tomorrow and get a few
What? You're supposed to replace those???
JK
But, seriously, i've reused all of my crush washers 3-4x before replacing, including the one for the oil pan... Bad practice? Yes. Risky? probably. Problems/leaks? none so far.
JKBut, seriously, i've reused all of my crush washers 3-4x before replacing, including the one for the oil pan... Bad practice? Yes. Risky? probably. Problems/leaks? none so far.
