difference between ap1 o2 sensor and ap2?
Old Sep 5, 2006 | 08:15 PM
staticx1134's Avatar
Default difference between ap1 o2 sensor and ap2?
Hi, I need to replace my primary o2 sensor....Are all the primary o2 sensor plugs the same??
Thanks
Old Sep 5, 2006 | 08:21 PM
Slows2k's Avatar
The AP2 connector shells are different colors and they may be different male/female as well. Not all primary sensors use the same side of a 4 pins connector shell, so you can't install them in the wrong place.
When in doubt, get the correct sensor for the year car you have.
Old Sep 5, 2006 | 09:00 PM
Kermdaddy's Avatar
I had one go bad a couple of months ago on my AP2. It put a big hurting on my gas milage. I got somewhere around 16 mpg, with minimal VTEC. I would get it fixed pretty soon. Mine was still under warrenty but it won't take long for the added gas price to offset the O2 sensor cost. Here is the part # they put on mine
36532-PZX-A01
Sensor, RR. Oxygen
$254.16
Old Sep 5, 2006 | 10:48 PM
NFRS2kSi's Avatar
different male/female?????
all o2 r same.. u can even pull o2 from civic & stick it into s2k...
Old Sep 6, 2006 | 04:15 AM
Slows2k's Avatar
Not true. Primary and Secondary sensors have different heater circuit resistance, and the connectors are different.
HankookS2K
Oct 9, 2014 05:39 AM
chris2k03
May 9, 2014 11:06 AM
08s2000CRbackinblack
Apr 23, 2012 09:09 AM
s2k_2fast4u
Jul 6, 2010 08:03 AM
