Differential OIL question
Old Jul 29, 2008 | 02:31 PM
Ben2K's Avatar
Default Differential OIL question
Can i use this oil for the differential ??
DuraBlend Gear Oil GL-5 LS
Applicable where an API GL-5 gear oil LS is specified
Available in a 75W-90 viscosity grade
For use in limited slip hypoid and other gears
Protects against rust and corrosion
GL-5 or GL-5 LS ??
Old Jul 29, 2008 | 03:35 PM
B serious's Avatar
no. the LS probably means it's got a limited slip additive used for clutchpack LSDs. It's an abrasive substance added to the oil.
Use regular ass 75W-90, 80W-90, or SAE 90WT GL5 gear oil meant for hypoid gears.
You can also use synthetic.
No special additives.
Old Jul 29, 2008 | 04:15 PM
Ben2K's Avatar
Like the castrol ?
EPX 80W-90
Extreme pressure; multi-purpose mineral oil; designed for the lubrication of spiral bevel; hypoid differentials and manual transmissions where the manufacturer recommends the use of an oil to API GL5 performance level
This differential oil is not recommended for Limited slip differential.
The differential of the S2k is limited slip no ?? LSD hum hum
Old Jul 29, 2008 | 04:20 PM
JDM06S's Avatar
I run Redline 75w-90 & have had no problems. A couple of other S2K owner friend run the same & have nothing bad to say.
Try & stay away from regular 75/90 use SYN only. Just so you are aware most all Honda Dealers only use castrol Syn gear oil 75/90. I don not recomend it at all. On my first diff oil change that fluid looked like crap & ever since using Redline the fluid look just as good as when it went in.
Hope this helps.
Old Jul 29, 2008 | 04:28 PM
Ben2K's Avatar
Thx for the reply
The problem is, here ine Belgium i can t find a lot of brands.
Castrol or Valvoline like the picture.
When i read the box, it s for use with Hypoid LSD and the S2k has a LSD with hypoids gears.
What is the problem ?
Old Jul 29, 2008 | 06:07 PM
thereur's Avatar
What's wrong with the Shell Spirax to the right side of the photo? It's GL-5 and full syn.
Specs:
http://tinyurl.com/6rndd8
Old Jul 29, 2008 | 06:21 PM
iDomN8U's Avatar
Originally Posted by Ben2K,Jul 29 2008, 08:28 PM
Thx for the reply
Nothing, both will work fine in your diff.
Lord-Jaffa
Nov 26, 2009 06:08 AM
owenxguo
Mar 19, 2007 03:09 PM
topcat7111
Sep 30, 2004 06:58 PM
rich1077
Mar 3, 2002 08:16 AM
vlopes
Jun 1, 2001 12:12 PM
