Difficulty in shifting
Old Oct 20, 2005 | 04:22 AM
TwiztedS2K's Avatar
Default Difficulty in shifting
Hey guys, whenever I am driving around town, or just simply starting off a drive by putting my baby into gear, I feel tension. Could this be a clutch going bad? I have MY00 with around 55k on it. Everything else is working great on the car. I was sitting still the other day in my driveway, and just ran through the gears slowly, and I noticed that with every gear I heard 2 clicks rather then just the one click going into gear. I know that might sound confusing, but it is kind of hard to explain. Any ideas?
Old Oct 20, 2005 | 05:12 AM
Balboa's Avatar
First thing....GM Syncromesh Friction Modified tranny fluid. About $11/quart (need 2 quarts, car takes 1.5ish) from your closest Chevy dealer.
Old Oct 20, 2005 | 06:37 AM
TwiztedS2K's Avatar
It was just 5k miles ago I put Mobil tranny fluid in there. Does it go bad that quick?
Old Oct 20, 2005 | 08:25 AM
apex2k's Avatar
I mean no offense by this, but was the correct fluid used on the last change? Also, I don't know if Chevy dealers are carrying the GMSFM, I thought it was Caddy stock or the marketplace here on S2KI.
Old Oct 20, 2005 | 09:52 AM
TwiztedS2K's Avatar
None taken. Yes, I am pretty sure it was the correct was used. I can't remember the exact numbers, but I know it was Mobil. There were several members on here that suggested it to me, so I know it was the right kind.
Old Oct 20, 2005 | 10:12 AM
TR-S2K's Avatar
I bought GMSFM at a Chevy dealer in Orange County, CA few days ago. The GM part number is 12377916
Old Oct 20, 2005 | 11:02 AM
SIIK2NR's Avatar
Couple of things comes to mind and that's:
What is your driving style?
Could it be your synchros?
Do you rev match or skip gears?
Old Oct 20, 2005 | 11:12 AM
jugger23's Avatar
I get the same thing, difficulty of shifting. I have not driven my car for about 10 days or more. All of a sudden it just happened.
I dont drive too agressive.
I never skip gears either.
Old Oct 20, 2005 | 11:28 AM
TwiztedS2K's Avatar
I only skipped gears one time since I have had the car. By rev-match, do you mean reving up to the appropriate rpm when downshifting? If so, I do that occasionally. Would that cause a problem? I dont drive my car hard, well, I mean extra hard. As an S owner, we all have to get on it sometimes, right?
Old Oct 20, 2005 | 11:56 AM
SIIK2NR's Avatar
Rev-matching is always better when you downshift... Although not everyone does it......it's a good habit.
Sounds like you need to do a double check on your fluids in the tranny.
