Difficulty shifting into 1st and Reverse
Old Feb 6, 2012 | 07:35 AM
TougeS2k's Avatar
My car has never liked first unless its warm, but i seem to have become automatic on hitting 2nd then first when cold.. really not a big bother to me, at least master/slave cylinder/reservoir work isn't too hard, i can wrap my brain around that stuff, very simple
Old Feb 6, 2012 | 06:23 PM
elksman's Avatar
Well, I just replaced the slave cylinder and flushed the fluid. First and especially reverse is still difficult to enter after starting the car, and sitting in neutral for a minute or two. Oddly enough, If I start the vehicle, and keep the clutch pedal down, I can easily enter first or reverse directly. (After some more time with the car, the issue with 1st seems to be resolved) Reverse is still difficult which is fine I guess.
I'm going to try changing the tranny fluid and see if it makes it any better. I found a tsb on the internet "SN031007 OCT 03 M/T - Hard To Shift Into 1st Gear, Grinds Into Reverse" But couldn't find any more documentation as far as a fix goes. I found some other posts by members who stated when their clutch was replaced as a result of the clutch buzz tsb, the issue went away.
(In fact, the only real issue now is reverse, and clutch drag about 50% of the time where I'll disengage the clutch and the shifter will not leave the gear.
Can anybody shed any light into this.
Thank
Old May 17, 2012 | 10:22 AM
G007's Avatar
Thank
I am having the same issue, any details on this would be great!
Old May 18, 2012 | 11:23 AM
elksman's Avatar
Since it's warmed up, the transmission is cooperating a little better. I still have resistance putting the car in neutral under 2000 rpm's. Makes bumper to bumper traffic a pain. I still have the put the car in 2nd /4th to get it to enter reverse and 1st if the car has been sitting a few hours.
I will be replacing the clutch in the next 6 months and let you know how that goes.
Old May 18, 2012 | 11:39 AM
DallasAp1's Avatar
It takes you 6 months to change your clutch fluid
Old Jun 5, 2012 | 09:42 PM
!@#$%'s Avatar
I just got my ap1 back from the shop with a new clutch, flywheel and ap2 trans. On the way home, the car felt great. Then out of nowhere I was locked out of every gear. Gonna have to have it towed back tomorrow and have them check my cmc and slave. Maybe my shshift fork shifted or something. I really have no clue.
Old Jun 29, 2015 | 05:56 PM
Soviet's Avatar
Any update?
Old Jun 29, 2015 | 06:18 PM
meccjoo's Avatar
Originally Posted by alricl
try new clutch fluid, trans fluid and regrease the shifter assembly
This ^
Also check the free play on your clutch pedal.
Old Jun 29, 2015 | 06:52 PM
B serious's Avatar
^Can't believe nobody suggested this before. You have to adjust the master cylinder after install.
Old Jun 29, 2015 | 06:54 PM
Soviet's Avatar
If anyone cares. I have the same issue myself.
Just replaced the transmission fluid. No change at all. Going to check the free play on the clutch pedal.
