The DIY Oil Change
Originally Posted by [gTr
,Jan 20 2008, 09:29 PM] When changing the filter the car actually takes 5.5 quarts instead of 5.1 a view supported by Billman going by his posts.
Originally Posted by gkb,Jan 21 2008, 08:15 AM
Bat711:
Do you take the car back to the dealer to reset your maintenance minder?
my stealership told me to fill 5.5 quarts. i was questioning the correctness of it since in my previous 06 model which i did all the oil changes in, i always used only 5 quarts and it was fine. so the actual amount needed is 5.1?
edit: i now have an MY07. pretty much no difference to the amount of oil i need
That's crazy talk!
My oil change consists of:
- 17mm socket and ratchet
- Channel locks (much better than a filter wrench
- Oil catch pan
- New filter
- "5.1" qts. of your preferred 10w-30 motor oil (or 5w-40 if you will be seeing regular -0F temps)
- 2 2x4s to roll the front wheels up on to.
The trick is to get yourself a CAI so that there is no need to go under the car
)- Oil catch pan
- New filter
