DIY: Replace dash light bulbs (AP1)
Old Nov 11, 2018 | 08:02 PM
  #111
jimmyfu's Avatar
Thinking about doing this over the winter; I can figure out the LED codes but since polarity matters, I'll need to plug in the dash and the battery to test before bolting everything back up. Would the airbag go off if the steering wheel column is still lowered?
Old Feb 26, 2019 | 09:49 PM
  #112
Kenshyn's Avatar
More than ten years old now lol. Maybe if a mod sees this, they can edit/update the original post as all the numbers for the Radio Unit Side have changed. I also added bulbs for other switches to the list for easy reference. Maybe also include this link to removal/install procedure since it has pictures: http://www.qube-engineering.com/Docu...nsAP1_v1.1.pdf
Radio Unit Side Required Bulbs
- (4) 35855-S2A-505 (Short Black)
- (1) 35851-S2A-505 (Short Black) for Start Button
- (1) 35855-S2A-506 (Short White) for Audio Control Mode Button
A/C Unit Side Required Bulbs
- (2) 79628-S2A-003 (Orange)
- (2) 79670-SL0-A01 (Long White)
Roof Switch Required Bulb
- (1) 35831-S2A-003
Hazard Switch Required Bulb
- (1) 35511-S2A-003
Cruise Control and Rear Window Defrost Required Bulb
- (1) 36776-S2A-003
- (1) 36777-S2A-003 is also listed for Cruise Control - This part number is for the green light on the button that lights up when cruise is activated.
Old Dec 20, 2021 | 03:29 PM
  #113
brokenbird's Avatar
Hey hey hey team, does anyone have guidance on vendors with these bulbs still available? I just picked up an S2K with nearly every bulb blown.
Old Dec 20, 2021 | 11:18 PM
  #114
Mr.Matchbox's Avatar
If you like to do fiddly work over winter, you should be able to purchase the bulbs alone at some elctronic store and replace them. The Bulbs are simply insertetd into the socket and the wires wrapped around it.
Old Apr 30, 2025 | 02:28 PM
  #115
TR25's Avatar
Originally Posted by kapitanemo
also ap2 has differences: there is a plastic bar under the column and hence the column does not 'completely' come down like it would on an ap1 i think.
niko
I just took apart my AP1 (received in April of 2000) and there is definitely a plastic bar under the column that would prevent it from coming completely down. However, the OP recommends leaving the bolts inserted a few turns, and that holds the column up enough that it doesn't rest on the plastic bar. I'd be worried that the column and steering wheel are heavy enough to break that plastic bar, so I didn't want to put any stress on it.
Old Apr 30, 2025 | 06:02 PM
  #116
TR25's Avatar
Originally Posted by animeS2K
5. Button it all up
Reattach the steering column
3. Torque all nuts properly (16lbf for the forward-most nuts, 12lbf for the mid-column nuts). See Photos for Reference
This wasn't clear to me, at first, with everything referred to as "nuts"
I think it's clearer to say:
16 lb-ft for the forward-most *bolts*
12 lb-ft for the mid-column nuts
Old Jul 22, 2025 | 08:27 PM
  #117
Fishwick2g's Avatar
- (1) 35831-S2A-003
- (1) 35511-S2A-003
- (1) 36776-S2A-003
This list was perfect for my AP1, thank you.
madmaxblaster
16
May 30, 2021 03:50 PM
bartonbeau
Nov 19, 2016 03:05 AM
Vinny_GPW-S2K
Apr 5, 2011 01:14 AM
BerlinaBlackS2kguy
Feb 20, 2007 02:07 PM
ras2k
Sep 19, 2002 02:24 PM
