DIY: Replace dash light bulbs (AP1)
look what i found! https://www.s2ki.com/home/2010/11/10...h-light-bulbs/
I almost got mad that someone was claiming this as their own until I saw the credit at the bottom... tho it'd still be nice for it to be right up at the top
I've updated the original post with the original content.
Just wanted to thank the OP and all who participated in this thread. I replaced my start button bulb using the pics and torque specs and it worked out beautifully! I even had the problem of not getting the dash to sit flush and realized that it was mentioned that one of the tabs could bend out of the way and sure enough on the top right one had. Thanks all!
So, would it be plausible for all your bulbs to burn out at once?
After starting my car the other night, all bulbs appeared to be working fine. (minus the start button, I had no Idea it was supposed to light up until I saw this thread)
Then as I drove the first few meters, the dash lights flickered and all went out. Also, the brightness control on my cluster appears not to work as well!
Is this a bulb problem or something else!?
Thanks!
Thanks!
I also just posted my own thread about replacing the template using Qubes engineering template. Recommend using a brighter led replace mention for the rpm and speedometer readout. Ordering those LEDs will post up my results!
This is a repost of what I just posted on my topic but showing you guys the difference in switching out the speedo's bulbs with 50% bright led ones!
Did receive my led 74 wedge bulbs today fior my speedo. They are suppose to be 50% brighter than stock. The reasoning, when I installed the Qube engineering template. The cluster faded out under direct sunlight or even with the top up was hard to see during the day. But these bulbs made a big difference. I did order sone type A T3 bulbs for the other components such a the cruise control button, defroster, roof, etc. But they sent me the wrong type. They sent me type B T4 bulbs. I already contacted my vendor so hopefully I will get these switched out for the correct size in blue.
As you'll see here that the super white bulbs I ordered are really bright! This is with the top down and outside! Lol can't wait to see how it looks like at night!
As you see here it's clearly obvious the new type B bulb won't work anywhere on our cars. I tried to find any bulbs I could possibly utilized the with. Even with my wife's Nissan. But no winner.
The first page of this topics should give you those part numbers. As in difference, I can't actually answer that. I sure they both share the same bulbs, but as in configuration they are different. What bulbs are you wanting to replace? Don't buy Honda oem bulbs! You will pay way too much!
https://www.s2ki.com/s2000/topic/891...hting-problem/
