How do you fix this gauge lighting problem?
Old Aug 22, 2011 | 09:38 AM
etang789's Avatar
Default How do you fix this gauge lighting problem?
How do you fix this gauge cluster lighting problem? Trying to help my friend out.
So far I know I think I need 1 bulb for the volume button, and the part number should be 35855-S2A-A11.
https://www.s2ki.com/home/2010/11/10...h-light-bulbs/
But what about the Tachometer? its very dim where the lower rpm is, its both dim if the headlight is on or not.
Attached Thumbnails How do you fix this gauge lighting problem?-img_2261.jpg   How do you fix this gauge lighting problem?-img_2262.jpg   How do you fix this gauge lighting problem?-img_2263.jpg
Old Aug 22, 2011 | 07:53 PM
etang789's Avatar
Old Aug 23, 2011 | 06:22 AM
MasterForce's Avatar
looks like it doesnt have that many kms/miles. maybe a trip to the dealer? pulling the tach out is really a hassle IMO.
Old Aug 23, 2011 | 07:22 AM
etang789's Avatar
haha my friend zeroed out the odometer when he got the car used.
Old Aug 23, 2011 | 11:28 PM
etang789's Avatar
Found this I assume its the Item #5
1 35505-SA5-003 SOCKET ASSY., BULB (14V 1.4W) (BASE:BLACK) (NS)
2 37103-SD2-003 BULB & SOCKET (14V 3W) (SOCKET:GRAY) (NS)
3 37103-S2A-003 SOCKET ASSY., BULB (3W T6.5) (CAP:BLUE)
5 78101-S2A-003 SOCKET ASSY., BULB (2W T5) (SOCKET:RED)
6 78102-S2A-003 SOCKET ASSY., BULB (1.12W T5) (LONG TYPE)
7 78103-S2A-003 SOCKET ASSY., BULB (1.12W T5) (SOCKET:GRAY)
Attached Thumbnails How do you fix this gauge lighting problem?-meter-components-ns-2-462369.png
Old Aug 24, 2011 | 08:42 AM
etang789's Avatar
https://www.s2ki.com/s2000/topic/601...t__p__20908551
Old Oct 22, 2013 | 09:38 AM
Croc's Avatar
good info.
i also need this to be replaced....
Old Oct 22, 2013 | 04:45 PM
maranelloboy05's Avatar
It's going to be expensive, but I suggest changing out pretty much all of them. You're going to kick yourself after pulling the cluster and then another goes out a couple weeks later.
Old Oct 22, 2013 | 05:36 PM
sillyboybmxer's Avatar
do them all at once!
Old Oct 22, 2013 | 06:16 PM
MBHs2k's Avatar
Thread is 2 years old
