DIY soft top adjustment?
Did a search with no resoults, any body has done this? im almost 100% sure i need to adjust my soft top roof (wind noise, clicking noises. vinyl seems loose?)
Is there a how to DIY or is it way to complicated, a "dealer only" matter
thansk alot for the help IA
if theirs wind noise in the front. i would say move the front lathes down slightly to pull the top closer against the rubber.. any other problem.. idk try some shinetsu grease.. it works wonders.. i even use it to clean off baked on caked on grease on pots and pans... well maybe i lied but its AWESOME stuff , almost as wonderful as the majik juice (WD40)
plus cliking noise on the front left latch.. and a "loose spring" like noise on the back (left side as well)as you can see its driving me CRAZY!!!!
Maybe i need to (somehow) tighten the driver side of the top a little?
I was starting to develop wind noise from the top front and the driver's window. I greased the seals all the way around with Shin-etsu on Saturday and left the car overnight with the top partially open.
Next day, no more wind noise. I'd definitely try this as a first step. Keep in mind it is a bit messy and the tops of your windows will be a bit greasy for a while.
Shin-etsu = Silicon grease
Have a look at this thread for more info on the latches
https://www.s2ki.com/forums/index.php?showt...0&#entry4635854
