Do I need to reset my ECU?
Old Sep 11, 2003 | 10:13 AM
S2KOwner's Avatar
Default Do I need to reset my ECU?
I have a CAI and now a Mugen header on my car, and was wondering if I need to reset my ECU to make everything run better? Sometimes when I come to a stop the car would almost stall out when I had the intake alone on it. The dealer installed the intake so I don't think they would have reset anything there. Let me know please.
Old Sep 11, 2003 | 10:31 AM
Gernby's Avatar
Former Sponsor
An ECU reset wouldn't hurt, but it isn't a must. The ECU will eventually relearn everything, but it will just take longer without a reset.
Old Sep 11, 2003 | 01:36 PM
oneaudiopro's Avatar
How do you reset the ECU?
Old Sep 11, 2003 | 01:44 PM
shockwave667's Avatar
Fuse box under the dash.
2nd fuse down on the right. The first slot will be empty so the 2nd fuse is located in the 3rd fuse slot.
Old Sep 11, 2003 | 01:45 PM
CoralDoc's Avatar
https://www.s2ki.com/article/articleview/5/1/8/
Old Sep 11, 2003 | 06:38 PM
Gernby's Avatar
Former Sponsor
I prefer to just wet my balls, and lay them across the battery terminals for about 30 seconds. It works every time.
Old Sep 11, 2003 | 06:39 PM
Gernby's Avatar
Former Sponsor
Of course, then I have to clean off my valve cover...
Old Sep 12, 2003 | 01:51 AM
simons2k's Avatar
Can't you just disconnect the neg battery cable for a couple of minutes to get the ECU reset?
Old Sep 12, 2003 | 05:13 AM
Gernby's Avatar
Former Sponsor
You can, but it is less effort to just pull the fuse for a couple minutes. If you disconnect the battery, then you have to reprogram your stereo.
Old Sep 12, 2003 | 06:51 AM
payyourtoll's Avatar
[QUOTE]Originally posted by gernby
[B]I prefer to just wet my balls, and lay them across the battery terminals for about 30 seconds.
