Does this sound normal?
you are fine to drive. if it were bad the noise would be very obvious.
i would say that morelikely than the alt it is the idler/tensoiner pully. in my expirience not counting the s, they go bad a lot more.
the idler pully is the one that doesn't do anything.
Remove the belt.
spin all pulleys by hand, wiggle them, whatnot. Loose or freeplay=bad.
Grinding kinda inside, or catching when you turn them = bad.
inspect the entire contact surface of the pulley, it should be pretty smooth and not out of round.
