Does the VAFC have to be dyno tuned to work right?
Old Apr 27, 2003 | 10:01 PM
revhi's Avatar
Default Does the VAFC have to be dyno tuned to work right?
I am getting a VAFC but not sure about tuning it. Does it need to be tuned on a dyno or can I use the settings posted in previous forums?
Does it need to be tuned again after every mod or if so what type of mods?
Old Apr 27, 2003 | 10:07 PM
sebrings2k's Avatar
Dyno tune is a must!!!
Eventhough you might have the same mods as another member on this board that might have posted a V-AFC tune guide, every car is different.
Old Apr 27, 2003 | 10:48 PM
AusS2000's Avatar
You can run a V-AFC with blank settings as long as you follow the set up instructions correctly, but you will get no gain.
You can lean out progressively from about 4K onwards as that's all the settings usually end up being. But if you've spent $4-500 on the V-AFC spend the extra $100 on the dyno time and get your moneys worth.
Old Apr 27, 2003 | 10:51 PM
revhi's Avatar
anyone know of dynos around the philadelphia area
Old Apr 27, 2003 | 11:35 PM
bayarea408's Avatar
expect only a mediocre 5-10 hp gain after spending $400 + for installation of VAFC and also dyno tuning.
Old Apr 28, 2003 | 05:47 AM
VTECPHIL#6829's Avatar
4-5 HP seems low as a peak gain with VAFC even on a stock car. It seems the 00-01 models stock get better returns than that. I gained way more than that peak and over10 hp across the board with my S/C application. Put in in perspective-even if this gave you only 5HP for $500, that is $1700 less than the 5 HP you don't get from the Amuse dual Titanium exhaust and other expensive exhausts, for example!! The VAFC is also the stepping stone needed to get the most out of future mods you may have in store. Pt
$Piker
Jan 19, 2009 12:38 PM
sick_speed
Mar 31, 2004 11:25 PM
HARDtoTOP
Sep 2, 2002 10:55 PM
crockey
Mar 10, 2002 10:47 AM
