DONUTS
Old Sep 14, 2009 | 05:54 PM
AusS2000's Avatar
Default DONUTS
I'm about to take a spare valve cover to the powder coaters. Thought I better strip out all the rubber before they put it in the oven.
I pulled lightly on one of the spark plug donuts and it ripped. Stuffed if I can get them out.
Do they come out? Can you replace them? What's the trick?
Old Sep 14, 2009 | 06:22 PM
chris_barry's Avatar
Put a screwdriver in from the outside and try to angle it so it presses against the solid section of the seal, then hit with a hammer to drive it out. You will trash them when you remove them.
Otherwise, from the inside, use a dot punch to tap the outer edge of the seal away from the cover enough so you can grab it with long nosed pliers.
Old Sep 14, 2009 | 06:23 PM
BTW, screw some bolts with wide washers in where the coil packs are bolted to the cover. They use this surface (not the threads) for their earth. Saves having to scrape away the power coating later.
Old Sep 14, 2009 | 06:59 PM
AusS2000's Avatar
Got them out. Damn they were cooked in tight.
Chris, do you get donuts with those gasket kits you buy?
Old Sep 14, 2009 | 08:02 PM
Yes.
Old Sep 14, 2009 | 08:41 PM
AusS2000's Avatar
Good stuff. I'll order one now. Which vendor do you prefer?
Old Sep 14, 2009 | 09:25 PM
Nickamsweet's Avatar
Also ensure that they do not touch the inside of the valve cover with shot blasting etc...
good luck
Old Sep 14, 2009 | 09:51 PM
AusS2000's Avatar
Thanks Nick.
Old Sep 14, 2009 | 11:03 PM
Fast Jack's Avatar
Remember the guy that powder coated his valve cover and ended up with gasket material in his vtec screen.Said,he hoping none of it made it to the oil sump but was going to pull the pan to see.
Old Sep 15, 2009 | 06:13 AM
Wildncrazy's Avatar
I'm soooooo disappointed. I thought this was going to be a thread on how to get free donuts. I guess I should have realized this is Under The Hood and not OT. Really got my mouth watering too.
