drivers side window?
Old Jul 5, 2011 | 02:10 PM
USAF_S2K's Avatar
Default drivers side window?
curious if anyone else has this issue or if its common. when i drop the top on the S my driver side window only rolls down about 3 inches and stops. passenger goes all the way down. i have to use the switch to roll the window the rest of the way down. any input would be helpful, thanks.
Old Jul 5, 2011 | 07:06 PM
RedY2KS2k's Avatar
Quite common problem on the earlier cars. You can search on things like "auto down reset" but there's conflicting evidence as to whether it works. You can spend money fixing it, or just lower the driver's side window using the switch in the door. It's up to you.
Old Jul 6, 2011 | 04:59 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
I did this reset thing years ago. It actually worked great and its been good ever since.
Has do do with the top module learning the full up/down positions of the window.
Old Jul 6, 2011 | 06:47 AM
USAF_S2K's Avatar
cool thanks, ill research the reset.
Chris Kimball
Dec 14, 2016 10:02 AM
TJF
Oct 28, 2010 12:06 PM
s2k harry
13
Aug 27, 2009 07:18 AM
Teh Legacy
Apr 13, 2008 05:41 PM
