ecu harness check...
Old Dec 17, 2004 | 12:03 PM
mikecl713's Avatar
Default ecu harness check...
how do u check the with the "voltmeter" on the ecu connections.....when i had the ems, the car shuts off when the harness was moved in a certain way...........now im trying to put back in the stock ecu, but before that i like to repair the bad connection.. how would one find the culprit wire??? do i need the car to be on the "on" position... dont u need the ecu in for that? or is that only to start the car?
Old Dec 17, 2004 | 12:13 PM
dut's Avatar
dut
- how about put stock ecu in, start car and wiggle the connectors/harness?
- maybe it was the EMS or the harness extension? lets hope it was the extension..
Old Dec 17, 2004 | 06:20 PM
mikecl713's Avatar
it wasnt the extension harness i was speaking of... i was talking about the stock harness.. one of the pins are bad and i narrowed it down to one of the connectors.......but i still need to know how to check for voltage in the pins.
Old Dec 17, 2004 | 06:26 PM
AusS2000's Avatar
You can't just test for volatge at the pin unless you know what is supposed to be at that pin. Some pins are 12V so you use a volt meter between the pin and ground. Some are ground, so you use a Ohm meter between them and the chassis. Some are signals to or from sensors or devices and may be voltages, resistance to ground, or pulsed signals.
Sorry this just ain't the way to test it.
What you have to do is narrow down what pins you think it might be and work out some tests for them. Or maybe just opwrk out where they go and put an Ohm meter between the pin and where they connect to whatever they connect to.
Old Dec 17, 2004 | 11:44 PM
mikecl713's Avatar
thanks aus......
is there a reference guide somewhere in the service manual??
i think it narrowed it down to one of the connectors............
Old Dec 18, 2004 | 02:31 AM
AusS2000's Avatar
You need to download the AEM EMS manual. It has a complete guide to pinouts.
sapone
Jul 12, 2011 11:15 AM
joes sled 2000
Aug 7, 2009 02:28 AM
s2kfolife
Oct 24, 2007 09:01 PM
S-EMPIRE
Apr 21, 2006 12:56 AM
