ECU and O2 sensor issues
Old May 17, 2014 | 05:07 PM
Pacman123's Avatar
Default ECU and O2 sensor issues
Hi Guys,
I tried searching for the answer but I only get bits and pieces of information.
A few weeks ago I removed the rear housing of my gearbox and replaced a couple of bearings on the output shaft. I disconnected both O2 sensor connectors and moved the wiring out the way to make it easier. After I had finished, I put it all back together fine and proceeded to plug the O2 sensors back in.
Not looking, but feeling with my fingers, I plugged the sensors back in and started the car. Immediately I had a CEL come up on the dash. I checked the codes and it said both O2 sensors were dead. Thinking this was odd, I went back under the car and had a look. Turns out I was able to plug the ECU directly into itself and the O2 sensors into each other :S. I would not have thought that the two O2 connectors (directly next to each other) were the opposites of each other and even able to do that. I felt like such a moron.
I plugged the O2 sensors into the ECU harness properly this time, but now I have a constant P0135 code and CEL come up.
Question is, have I killed something in the ECU? or is it just unfortunate timing and the primary O2 sensor heater is dead? Has anyone else had this experience?
Old May 19, 2014 | 08:19 AM
s2klariat's Avatar
Did you reset light after switching back? Pull back up fuse for a couple of minutes and plug back in.
Old May 19, 2014 | 08:36 AM
iamxpl's Avatar
o2 sensor CEL will stay on until drive cycle is complete.
Old May 20, 2014 | 04:09 PM
SlowzS2K's Avatar
I have the same problem. ECU harness was connected to itself and the o2's were connected to each other. I corrected the connections and reset the ECU by disconnecting battery for 5 minutes or so and then letting it idle for about 10 min.
The CEL came back on right away and i have driven i dont know how many cycles and about 200 miles since
Symptoms are poor acceleration and VERY low idle, its even stalled a few times at a stop.
PS: New to the forums but not the S!
Old May 20, 2014 | 11:59 PM
Pacman123's Avatar
Thanks for the replies. Yea did all that unfortunately. Reset ecu, reset codes etc several times now. Unfortunately SlowzS2k post now sounds awfully similar.
I assumed it really wasn't good for the ecu, but seems rather stupid by Honda, although more stupid on my end too.
If I get a moment, i suppose i will test the heater circuit on the O2 sensor, and maybe try a new one to see if it fixes it. :S
unless anyone has any other ideas/ suggestions?
thanks all.
Old May 21, 2014 | 02:27 PM
SlowzS2K's Avatar
Yea im thinking that maybe the heater circuits in the o2's got damaged since they weren't meant to be plugged into each other but who knows. Im gonna order 2 new sensors from rock auto for a decent price and hope that the ECU didn't get F*%#d!
Iv learned my lesson not to do that again
Old May 23, 2014 | 09:58 PM
Pacman123's Avatar
Yea tell me about it :s who would have thought.
I am parking the S2k in the next couple of weeks due to respraying the front right fender and a couple of other small repairs.
I will test the O2 sensor and circuit at the same time when I get it up on some ramps.
I guess I will keep everyone updated.
Old Aug 1, 2014 | 07:33 PM
eddiezzxdeeto's Avatar
I did the same exact thing that both of you guys have done..... I was wondering if you guys were able to fix your problem. So far ive tested the voltage coming out of the ecm and I got 12v on primary heater and 3v on the secondary heater. When I have the car running the voltages dont go back and fourth like theyre supposed to. I checked my wires for any resistance but they had none. Im thinking its my ecu but I want to make sure thats what it is before I go out and buy one, thanks in advance.
Old May 21, 2015 | 05:41 AM
Psyr's Avatar
Any follow-ups here? I've been having O2 issues for quite some time and I would like to know if O2 sensors fixed this issue or if it is an ECU?
Old May 21, 2015 | 08:44 AM
flanders's Avatar
Connecting the two sensors to each other should not affect them at all, it's most likely an ecu problem.
