ECU reaction with VAFC?
Old Sep 26, 2006 | 10:07 AM
EK9MAX's Avatar
Default ECU reaction with VAFC?
Rumour has it that the ECU compensates with VAFC values.....
Is there any truth to that?
I'm assuming it would ot the same on a greddy emanage too then?
Old Sep 26, 2006 | 11:06 AM
AssassinJN's Avatar
This is true on all "biggy-back" style computers. You should reset the ecu every week or so seams to be the consensus.
Old Sep 26, 2006 | 12:36 PM
blackey's Avatar
That's just about right. At part throttle, the ecu reads all the signals, including the O2 sensors, and adjusts the fuel tables based on the parameters. The Vafc on really adjusts what the ecu sees as airflow, so over time the O2 sensors will bring the settings back into line with what it expects. You could constantly reset the ecu, but they run really poor after that for a time while they relearn.
When the ECU goes to WOT, it stops reading the O2 sensors and goes into what they call open loop mode. If you only set the Vafc to modify the fuel at WOT, then the tune will stay. It's a good piece for the money. You can modify the VTEC point, and pick up some good hp at WOT. It does have to be tuned on a dyno to get the right settings. For $250 + tuning, what else will give you 10RWHP? That being said, it cant modify settings for cruise, idle, etc...
It also can't modify timing, so it has it limits. An AEM EMS is a more capable solution, but it starts at $1300 plus tuning.
Old Sep 26, 2006 | 01:06 PM
EK9MAX's Avatar
I'm just worried that tuning of an EMS is gonna be a PITA. Because it'll never be perfect. And this car is a daily driver......
EK9MAX's Avatar
So the emenage is the same way? IF I only tune wot then it's ok??
Old Sep 26, 2006 | 01:42 PM
Johnny Sack's Avatar
i love my vafc and recently adjusted my setting to only apply at WOT, the car runs basically the same and i dont have to reset my ecu every two weeks. the dyno numbers in my sig are off my re-tuned vafc.
Old Sep 26, 2006 | 01:43 PM
RED MX5's Avatar
[QUOTE=EK9MAX,Sep 26 2006, 04:06 PM]I'm just worried that tuning of an EMS is gonna be a PITA.
Old Sep 26, 2006 | 01:51 PM
djpeak10's Avatar
what about a vortech black box piggy back computer, are you saying for optimal performance I need to reset the computer every couple of weeks?
Old Sep 26, 2006 | 02:39 PM
s2kshift9k's Avatar
this seems to be troubling kinda not makin me want to get that vafc II
Old Sep 26, 2006 | 03:26 PM
xviper's Avatar
No need to reset the ECU with this. The VT black boxes only infiltrate the timing to a slight amount and the act as a MAP clamp. They don't do anything with fuel.
