Effect of lots of Toe In
Old Dec 9, 2001 | 06:13 AM
Prolene's Avatar
In another thread, I had tried to describe how it felt my stock suspension car was cornering, how it didn't seem correct, with the fronts working very hard on turns and xs front wear (Spoon wheels). When I took the S2000 to West End Alignment, Darrin checked the alignment and said the back was likely being "very lazy". He asked what my driving habits were like and decided to set my car up for agressive street/occasional track alignment. He had initially found 1/8" total toe in in the rear. I forget how much toe in he dialed out with alignment.
After alignment, the car handled delightfully, and felt very good around corners, like being on rails again. I could even take some very tight canyon corners faster; previously, I couldn't use some power because it just went to push the front out of the line. At Streets of Willow, the car felt balanced (instructor also mentioned this, but he didn't drive), even if the back end stepped out twice. I was able to correct steering and catch the back safely each time.
Alignment and alignment preferences have a lot to do with how the car feels.
Old Dec 13, 2001 | 07:25 AM
REVM's Avatar
I recently had my car aligned and here is what they ended up with:
Left Front: Caster(5.0); Camber(-.5) Toe(0)
Right Front: Caster(5.5); Camber(-.3) Toe(0)
Left Rear: Camber(-1.0) Toe(.05)
Right Rear: Camber(-1.5) Toe(.05)
The previous settings were:
Left Front: Caster(5.0); Camber (-.5) Toe(.05)
Right Front: Caster(5.5); Camber(-.3) Toe(.05)
Left Rear: Camber(-1.2) Toe(.45)
Right Rear: Camber(.85) Toe(.05)
As you can see, they made some adjusments. I have to say that the rear of the car definitely seems less planted than before and has more play in it around corners and is less than confidence-inspiring. My question is what setting/settings loosened up the rear?
Old Dec 13, 2001 | 08:10 AM
marcucci's Avatar
That rear toe of .45 was WAY off from the other side, but probably helped keep your tail end in line. If you feel a little more squirrelly, you might want to have the rear toe brought in a little bit, maybe .1 or .2 a side. This should bring back what you felt a little more. With the front toe you have now, that should make a pretty good combination for neutral handling (or at least less oversteer).
Old Dec 13, 2001 | 08:18 AM
cdelena's Avatar
I have no idea why it is not even side to side.. the rear would be a bit more loose with the reduction in toe-in. Here is a suggested street target..
Left Front: Caster(6); Camber(-.75) Toe(0)
Right Front: Caster(6); Camber(-.75) Toe(0)
Left Rear: Camber(-1.5) Toe-in(.125 inch)
Right Rear: Camber(-1.5) Toe-in(.125 inch)
Old Dec 13, 2001 | 10:01 AM
RT's Avatar
RT
[QUOTE]Originally posted by cdelena
[B]
Old Dec 13, 2001 | 10:57 AM
cdelena's Avatar
Originally posted by RT
Chris, do you run that much rear toe or are you just suggesting it to calm down the loose rear complaint from REVM?
I always ask for a bit less than that (5-6mm total) but since the readout is degrees rather than linear I have to double check my current alignment..
Old Dec 13, 2001 | 11:13 AM
RT's Avatar
RT
I think 1/8" per side (1/4" total toe ~ 6mm) is 0.29 degrees per side (0.58 degrees total toe).
LOL, doesn't it seem like we go through this conversion every other month or so? Each time I hurt my brain trying to think it through.
Old Dec 13, 2001 | 12:04 PM
cdelena's Avatar
[QUOTE]Originally posted by RT
[B]
Old Dec 13, 2001 | 12:58 PM
RT's Avatar
RT
I know it is a pain.. I just looked and the last read out shows .23R and .24L toe-in. It is very stable this way. I am changing springs this month (Comptech springs and perches modified to work with my Konis) and intend to align to -1.25, -1.75 and leave the toe about the same.
So it looks like you are 0.100"R and 0.104"L (0.204" total toe-in). Amazing, the conversions actually sound right
helpilot
Jan 5, 2013 05:38 PM
elksman
Jul 16, 2012 08:37 AM
Scot
Apr 25, 2005 03:32 PM
RobC2
Apr 20, 2005 03:23 PM
jguerdat
Apr 30, 2001 11:02 AM
