EGT Gauge Bouncing...
Old Feb 13, 2002 | 08:57 AM
Wesmaster's Avatar
Default EGT Gauge Bouncing...
I don't really think it's much to worry about but thought I'd double check.
I've noticed that sometimes my EGT gauge will bounce down (not sure if it ever goes up) about 20 degrees C, and return to it's constant temp right after that. So, the needle sorta jumps and returns instantly. I've assumed that it's either a malfunction in the gauge/wiring, or worse case scenario, there is slight detonation, but I would assume that would produce higher temps, not lower...but I'm just speculating. I've only noticed this during stead operation, not WOT.
So does anyone know if the jumping has anything to do with the engine, or do you just think it's the gauge?
Old Feb 13, 2002 | 10:01 AM
txst's Avatar
If the needle jumps almost instantly, I wouldn't worry too much about it - especially if the temp goes down not up. All sensors/gauges have some amount of hysteresis when they are functioning correctly which prevents them from doing anything instantaneously.
Old Feb 13, 2002 | 12:32 PM
Ludedude's Avatar
Administrator
Has to be the gauge, or more likely the temp sensor.
It might have vibrated loose and you're losing ground or the sending wire
is pinched etc. Gauges, especially of the temperature variety, don't respond instantly..also, it's not likely that your exhaust drops 20 Deg C and bounces back in the space of a few milliseconds.
Old Feb 13, 2002 | 01:06 PM
RT's Avatar
RT
Wes, temp can't change that fast, too much thermal mass, got to be a loose ground or something. Another way to think of it is if a Tach did the same thing, there's no way the inertia of the moving parts can change speed that fast. Know what I mean?
Old Feb 13, 2002 | 01:08 PM
Wesmaster's Avatar
Cool, I just figured that if there was a misfire, or something, for that one stroke the temps would be quite different...but possibly not measured quite that fast by the gauge.
Old Feb 13, 2002 | 01:27 PM
Ludedude's Avatar
Administrator
Heh, it would nice to see that misfire in the space of a few milliseconds, wouldn't it?
Think of how fast the exhaust gas would have to cool, given the rpm of the motor, and how fast that
"cooler" pulse is whizzing by the sensor and then think about how fast the sending unit and gauge would have to respond before going back to normal temps for the next pulse.
One way to achieve that would be with 4 sending units, one in each header pipe, to monitor each
cylinder separately, but you still wouldn't capture an isolated event of a few miliseconds duration.
Anyway...yeah, check the sending unit and/or wiring
Old Feb 13, 2002 | 01:42 PM
RT's Avatar
RT
I think Wes is only checking temps from one cylinder (way upstream of the collector).
Old Feb 13, 2002 | 01:46 PM
Wesmaster's Avatar
Originally posted by RT
I think Wes is only checking temps from one cylinder.
Yep, #3.
Old Feb 13, 2002 | 02:07 PM
RT's Avatar
RT
Originally posted by Wesmaster
Yep, #3.
amazing, I still can remember some things (too bad they're obscure as hell things)
boyguan
May 3, 2013 03:10 PM
yiannakos
Jul 30, 2007 12:18 AM
Reaper 6A
Feb 23, 2007 12:15 PM
