Electric Water Pump Interest Inquiry
Old Aug 22, 2003 | 07:10 AM
Prolene's Avatar
Originally posted by ultimate lurker
Also, will you be developing a block off plate so that the stock water pump can be removed, or will it be left in place?
UL
For the price I thought the blocking plate would be included in this. I think the stock pump should be removed, as this may help coolant flow as well.
Old Aug 22, 2003 | 07:43 AM
krazik's Avatar
Administrator
[QUOTE]Originally posted by ultimate lurker
[B]Krazik, any reason why you're looking at an electronic thermostat?
Old Aug 22, 2003 | 08:24 AM
slick rick's Avatar
What's the reliability record on this?
Also, is there any fail-safe systems?
It seems pretty good in theory, but it also puts a lot on stake.
One thing I've heard about water pumps is that they flow too quick at higher rpm's and that water will actually cool a lot better when the flow rate is slowed down a little bit.
In karts, we had water pumps hooked up to the rear axle with a pulley.
Old Aug 22, 2003 | 08:32 AM
krazik's Avatar
Administrator
The I'm looking at is fairly new design, but the company has been making pumps for quite some time.
Not sure how to design a fail safe other than to watch the temp guage and/or install an extra water temp gauge. How do you currently watch for a water pump failiure? It can happen.
I guess could always install 2 pumps w/ one as a backup if you were really worried about failure.
Old Aug 22, 2003 | 08:34 AM
slick rick's Avatar
There goes the weight savings.......
Can you get an electric oil pump???????
Old Aug 22, 2003 | 08:36 AM
krazik's Avatar
Administrator
I'm not suggesting 2 pumps. But if you're uber paranoid.............. N+1 redundancy in geek
Also theres more to the water pump than weight savings. There would be a lot less drag on the engine too.
I don't know of a source for an oil pump, no.
Old Aug 22, 2003 | 10:43 AM
vapors2k's Avatar
Lol rylan, I was researching a system exactly what you described for awhile now, stuart pumps right? From what I understand, they have the most expierience in this field. Did you check out their integrated pump/radiator systems?
Old Aug 22, 2003 | 10:44 AM
Prolene's Avatar
Please let me know when you have all the components available for purchase. Thanks for doing the r&d!
Old Aug 22, 2003 | 01:17 PM
krazik's Avatar
Administrator
nope, not stuart pumps, but I'll check them out too.
Old Aug 22, 2003 | 02:22 PM
slick rick's Avatar
[QUOTE]Originally posted by Big Ben
[B]On V8's, an electric water pump is good for about an extra 20 horses at the crank. I would guess we could get around 15 at the crank.
