Electrical issue.
Old Oct 5, 2023 | 09:47 AM
Slowcrash_101's Avatar
Default Electrical issue.
My driver side brake light and side marker light don't work. I replaced the brake light bulb and nothing. Are the side marker and brake light on the same circuit? No blown fuses.
Old Oct 5, 2023 | 10:18 AM
Fixed it, they do share the same circuit. Changed the side marker bulb, brake light works now.
Old Oct 5, 2023 | 11:09 AM
engifineer's Avatar
I had the opposite issue, always popping the fuse when the brake pedal was pressed. And yep, it killed both! On mine though, the issue was kind of funny to find. Turned out the bulb failed, but one of the arms that hold the element in the bulb bent over to touch the other one so it was enough metal to not burn through and was shorting, killing the fuse. Did not expect that one! Started tracing the circuit from the fuse panel back and found that when the bulb was pulled the short went away
Old Oct 5, 2023 | 11:41 AM
Plot thickens, side marker works but driver side brake light doesn't
Old Oct 5, 2023 | 12:08 PM
I have narrowed it down to a bad socket. The wire and connector are getting power but not the socket where the light goes.
froppybirds
Jun 23, 2023 07:18 PM
_Kyo
Mar 7, 2011 04:15 PM
slammed ap1
Apr 13, 2009 06:15 PM
s2kcr
Bay Area For Sale
Apr 2, 2009 03:05 PM
