Engine is all fawked up! misfiring?
Old Aug 27, 2012 | 01:01 PM
liquid_helix136's Avatar
Default Engine is all fawked up! misfiring?
EDIT: So Compression test revealed that cylinders 1 & 2 (so far) have low compression (160) A couple questions of mine would be would 240 still be normal compression on a motor with 140k miles? Also, the spark plug broke off in cylinder 1, could it have done something that caused low compression in all the cylinders? They didn't test the last 2 cylinders for whatever reason, but I'm making them do it tomorrow so we'll see if the others are low as well
So on the way to class this morning, I was just driving around more conservatively than normal, trying to save some gas, shifting at 3k, cruising at 35 in 5th gear (4.77 rear end) and then I sped up to 40, and put it in 6th. Someone was turning off my road so I slowed to about 30 (still ~2k rpms) and when I tried to speed back up to 40 my car felt weird, and it started sounding like I had an exhaust leak, or that someone just dropped a subaru engine under my hood. I immediately pulled over and popped the hood to check things out.
All signs point toward a misfire, sounds like subaru boxer engine, car shakes and still drives, but runs like shit. But my wideband is reading 15.5-16.2 on idle rather than the normal 14.7. I grabbed my laptop (Im running on AEM EMS V1 so CEL codes are out) richened up the fuel map from 0-4k rpms and putted it the mile back home.
I'm on copper spark plugs, which need to be changed every 5k miles. It's been ~10k miles so that was obviously where I was going to start. But the thing that concerns me (and reason for this post) is that my AFRs were lean instead of rich. If there spark plugs were bad, the fuel wouldn't ignite, resulting in a rich mixture correct?
I haven't checked out anything yet, but would the lean mixture point to a bad injector? Or could a bad plug still result in lean AFRs?
http://www.youtube.com/watch?v=mSoxKMTzyOM
Old Aug 27, 2012 | 07:11 PM
So I checked the plugs today and this is what I found
From left to right is cylinder 1,2,3 and 4
Changed the plugs, started it up and same thing, hasn't changed at all. Plugs *should* be installed correctly, they are the same exact plugs I've been using and gapped them to about .035. Upon idle AFRs are still hovering around 15.7-16.2
Old Aug 27, 2012 | 07:29 PM
W84VTEC's Avatar
Why is the electrode missing on the cylinder 1 spark plug?
Also, i would unplug the EMS and see how the car runs on the factory ecu. If it still runs like trash, I would test the coil packs.
Old Aug 27, 2012 | 07:34 PM
^^^ exactly my question. I thought my whole problem was cylinder 1 wasn't firing because of this, but after changing the plugs, problem is still there. Maybe the conductor got blown off, went in the engine and f@#ked some shit up?
Old Aug 27, 2012 | 07:35 PM
I'm trying to upload a video from earlier today, valve train sounds noisier than normal.. I'm thinking there may be some damage in there
Old Aug 27, 2012 | 07:36 PM
Thateguhate's Avatar
Doesn't this happen when the spark plug comes loose? I could be wrong....
I swore I read this happening somewhere I'm just not sure what thread. I'm sure someone can help shed some light on this for you.
Old Aug 27, 2012 | 07:44 PM
When I pulled it out it seemed fine. I had to give it a little bit of torque to unscrew it. It wasn't like just bouncing around in there
Old Aug 27, 2012 | 07:45 PM
W84VTEC's Avatar
Sorry to hear that it broke off in the motor. You are in for a rebuild now
Old Aug 27, 2012 | 08:03 PM
s2000maniac's Avatar
Scored cylinder wall
Old Aug 27, 2012 | 08:13 PM
If It didn't come loose how did it break off into the motor? Now I'm lost.
