Engine coolant
Old Dec 5, 2005 | 10:13 PM
Green Tea's Avatar
Default Engine coolant
i was going over the fluid levels of my car today and noticed my engine coolant level was by the MIN, right dab on the "MIN" letter. After going for a drive I checked the fluid again and noticed the engine coolant level was near the top after a drive. Am I suppose to go upon the cold engine reading in the morning or after the engine is warmed up/driven a bit?
Old Dec 5, 2005 | 11:33 PM
Partshelper's Avatar
you should never have it full, whe n you run the car hot, it pumps out coolant into the resevoir, and when it cools down it takes it back in.
Old Dec 5, 2005 | 11:51 PM
Green Tea's Avatar
So i don't need to add coolant?
Old Dec 6, 2005 | 06:38 AM
xviper's Avatar
As with tires, you check coolant level when cold.
Old Dec 6, 2005 | 07:31 AM
Intrepid175's Avatar
Only if it falls below that minimum line when cold!
What you're seeing is perfectly normal.
Drive Safe,
Steve R.
Old Mar 27, 2008 | 01:57 PM
DJSang's Avatar
Thanks! btw, I miss xviper
mjweston
Aug 20, 2014 11:32 AM
shar77
Apr 29, 2009 09:55 AM
algeusis
Jan 9, 2008 01:22 PM
rocrfella
Aug 15, 2007 08:01 AM
9kscream
Nov 19, 2003 04:28 PM
