Originally Posted by rdv5434391,Feb 7 2008, 12:23 PM
-- it was perfect until installing the K&N, so something from the install is the culprit, just sorry to feel that this will be the price of having the K&N
Helpful thanks :D
I don't think it was helpful, since it doesn't give a cause or a cure! There are several threads alluding to this same problem, but none of them pinpoint a cause or a cure (unless you count Shock wrecking his car and actually being relieved(!) because he didn't have to deal with the idle/stalling problem anymore). They just document the owner's endless efforts at troubleshooting.
This problem seems to be widespread on S2K's; does anyone know the cause and/or how to fix it? |
also coasting to red light and stuff in neutral will make the problem more apparent. Its confuses the ECU because the it senses the speed of the vehicle but the engine is trying to maintain an idle..search it up !!
So its normal when ever I disconnect the battery and then reconnect for my car to do this? I've had to disconnect it two times this week (installing new EPS / installing test pipe) and both times the car has a really low idle and stales? The car is acting fine now, I guess its just really weird for me since I've never had a car do this before. I thought it was a bad ground! Thanks for the information!
Originally Posted by Bizkit64
(Post 20325265)
yup same here i had that issue this morning i diconnected my ecu to reset it and was doing the exact same...i hope it goes away fast |
What if I am running an AEM Series 2 Plug & Play EMS? I don't believe it is a "learning EMS" as it does not use the O2 sensor for any feedback to manage the engine fuel & timing. It is my understanding that everything is set up by the tuner. If that's the case, why would I have an intermitent erratic (low) idle. When the cooling fans kick on the idle will drop down really low as well.
I also notice that the throttle will "hang" between shifts if I shift around 3,000rpm. This problem is not apparent at higher or lower rpms. I am running a Vortech SC with a 4 bar MAP (new in Nov 2010) and the PCV is going to a catch can. Any ideas? Maybe the IAC? Any help would be appreciated! Chris |
I agree with the OP. Good info there. As for the relearn idle procedure, if you every disconnect the battery and reconnect, it may be helpful to do the relearn. I had a low idle and hesitation to point of almost stalling, after disconnecting the battery for some work. I re-disconnected the battery to reset ecu, then did relearn idle procedure (good to have 2nd person watch when radiator fan comes on), and idle is all good now. It idles higher and no hesitation. If this doesn't help then revert to OP's post
What is a IAC?
Sorry for the bump, but the link for the "whack" method is dead(or is it just me?) can anyone explain how to do this method?
EDIT: I'll just leave this here for future reference: http://forums.s2kca.com/showthread.p...MAP-Whack-quot |
