Engine Knocking/Rattling
Old Nov 17, 2014 | 04:09 PM
  #101
Slowcrash_101's Avatar
Nope Oem bearings all the way and they don't need to be replaced as a set
Old Nov 17, 2014 | 04:54 PM
  #102
bgoetz's Avatar
Yeah I think you would need to go OEM and you need to size them perfectly, which is why this type of thing is best to leave to the experts
Old Nov 17, 2014 | 07:13 PM
  #103
Mexs2k's Avatar
Guys I think I found the problem at least I hope I did. I took the serpentine belt off and the noise went away.im going to recheck tommorow but how long can I run car without belt on. I'm crossing my fingers. I almost cried when the car idles smooth. My idler pulley has side to side play. I'm not sure if that's normal.i checked the bolt and it's on there really tight. So how can it have side to side play?
Old Nov 18, 2014 | 02:04 AM
  #104
bgoetz's Avatar
Bad bearings. It is a simple fix
Old Nov 18, 2014 | 02:14 AM
  #105
The webbing on the crank comes stamped with the bearings used, get the one that corresponds with your rod and the next two sizes up.
Old Nov 18, 2014 | 02:16 AM
  #106
Not long at all, no belt = no water pump action.
Old Nov 18, 2014 | 04:07 PM
  #107
HUNTERANGEL121's Avatar
Originally Posted by Slowcrash_101
Check the play vs service manual. I think ballade sells a bigger cam chain sprocket but idk if it would fix your issue.
Ballade sports indeed do sell one timing correction gear
Old Nov 18, 2014 | 05:52 PM
  #108
bgoetz's Avatar
That is very interesting. So the rattle could in fact be slack in the chain that creates a more distinct rattle from the compression of cylinder 1 or who knows the firing of cylinder 1 could somehow magnify the sound, IMO. I could still hear a faint rattle in your video even after the coil was removed.
Old Nov 20, 2014 | 05:44 AM
  #109
StrokerSi's Avatar
Exactly. I can take things apart and put them back together. When it comes to fine measurements, I try to stay away.
You're lucky. My sound stays with the belt removed. I replaced the bearings on those pulleys anyway since mine were a little wobbly too.
Yea, that led me to believe it was a piston/rod/pin issue since you'd still hear *something* banging around regardless of combustion.
Old Nov 20, 2014 | 07:41 AM
  #110
Mexs2k's Avatar
I'm not out of the woods just yet. I still have to buy the pulley and install and see how it sounds with load on it.im crossing my fingers though.
