Engine Mount Install
Old Mar 25, 2014 | 05:45 AM
Gottabfast's Avatar
Default Engine Mount Install
At first glance it looks like I can install these Innovative engine mounts without taking out/dropping the subframe since I'm taking out the mount and the engine bracket. If I hang the engine from above and do 1 side at a time, then final tighten when they're both installed it looks like there's enough space. Am I wrong?
Old Mar 25, 2014 | 07:13 AM
c130turboprop's Avatar
should be able to. i installed mine with the engine out, but i dont see why you cant install them with engine hanging... make sure whatever u hang it with your able to adjust up/down/side to side so u can line bolts up. also, i welded the bolt heads/washers to the bracket (the 2 bolts that go down through the subframe on each mount) tack welding them in place makes it much easier to tighten cause once the motor is in place, you cant get a wrench on the bolt heads. unless u torque them down and hope the actual engine mount lines up...
Old Mar 25, 2014 | 07:09 PM
Gottabfast's Avatar
Thanks! Hopefully it'll be warm enough to try it this weekend
Old Mar 26, 2014 | 06:20 AM
AE_Racer's Avatar
I've taken mine out and reinstalled with the engine in the car.. One at a time with a jack under the bellhousing. I had to pull them out to replace the 65A bushings, they went bad really quick. Hopefully you didnt buy those.
https://www.s2ki.com/s2000/topic/646...mounts-review/
Old Mar 26, 2014 | 06:39 AM
yamahaSHO's Avatar
I did mine one at a time with a jack (and 2x4) under the oil pan. I did have to move my header out of the way, but it is also aftermarket (PLM). You may not need to do that step.
Old Mar 26, 2014 | 10:29 AM
slowd16's Avatar
When I did mine with my berk header I was able to keep the header attached.Did it the same way with the jack and 2x4 too.
Old Mar 26, 2014 | 10:46 AM
s2000maniac's Avatar
When I did mines I couldn't get to top bolt for the passenger side. So I removed the whole bracket along with the motor mount from the block. Makes it much easier
Old Mar 26, 2014 | 11:19 AM
yamahaSHO's Avatar
IIRC, without moving my header, I couldn't get a bolt to back all the way out of the block. I figured removing the header from the head was a better idea than trying to flex the thin-walled PLM?
Old Mar 26, 2014 | 01:32 PM
s2klariat's Avatar
Just be sure you use the supplied bolts from Innovative. Do not reuse the factory bolts, you will crack a small piece off the inside of the girdle and the oil pump will pick it up and it will clog it. This will destroy your bottom end.
Old Mar 26, 2014 | 01:43 PM
slowd16's Avatar
Originally Posted by slowd16' timestamp='1395858592' post='23082533
[quote name='yamahaSHO' timestamp='1395844754' post='23082015']
[/quote]
I did it about 2-3 years ago so I don't remember everything about it but I know for sure I didn't unhook the header. Maybe the berk and the plm have slighly different bends in them.
