engine movement
So, I was in a wreck about six months ago, gettin my car back just about 2 weeks ago, and it is still not complete!
However, come to find out during the wreck(hit from behind)- the entire engine block jumped forward about a quarter to a half inch. Is this dangerous, a problem, not something to worry about?
Besdies balance issues(center of grav), what other problems can this cause? I was planing on installing a new header soon...could this create a problem with the install?
Thanks
Drew
Thanks
Drew
Definitly check the motor mounts! May problems can become of this. For example a wire harness may now be under tension or kinked and pinched which could wear out the insulation causing a short to ground and or a fire. That is one of many things that I can think of.. Play it safe and have it evaluated.
Congo
Nov 6, 2005 03:19 PM
