Engine Noise
Old Jul 24, 2008 | 12:19 AM
ztrujillo's Avatar
Thumbs up Engine Noise
Hello Everyone,
This is my first time posting, and I hope is under the right section.
I have an AP2, MY 07 with ~24,000 miles (it
Old Jul 24, 2008 | 05:31 AM
GT_NFR's Avatar
ticking sound is injectors. You're fine. s2000 have all sorts of noises.
How much oil do you add? I find adding 5.3-5.5 Qts of oil helps reduce the vavetrain noise significantly. The 5qts just doesn't cut it.
Old Jul 24, 2008 | 09:22 AM
s2k dre's Avatar
sounds normal, my ap2 sounds just like yours.
Old Jul 24, 2008 | 09:56 AM
fatjoe10's Avatar
Sounds like the timing chain auto tensioner going bad? compare to this vid, in which the sounds is very similar and the video poster said it was indeed the TCT:
http://www.youtube.com/watch?v=Y8hYA...eature=related
I hope that helps.
Old Jul 24, 2008 | 10:07 AM
3ngin33r1's Avatar
Sounds too quiet to be the TCT, sounds like normal valve train noise in a honda motor to me.
How loud is it with the hood closed?
Old Jul 24, 2008 | 01:41 PM
ztrujillo's Avatar
I will take a look at it. I might do an early oil change just to try 5.3 qt as you suggested.
Thank you!
Old Jul 24, 2008 | 01:43 PM
3ngin33r1's Avatar
Why would you measure what you put in from the container and not with the dip stick?
Old Jul 24, 2008 | 01:46 PM
ztrujillo's Avatar
Is not very loud, it actually sounds "normal" if I'm standing outside the car, but when I'm sitting I can hear that "tick, tick", is very faint thou.
Thanks!
Old Jul 24, 2008 | 04:47 PM
Togobox's Avatar
More video? give it some rev
Old Jul 25, 2008 | 11:59 AM
GT_NFR's Avatar
tick tick is def injectors. If tct was the problem it would sound more like a card in a bicycle spoke.
