Engine noise identification
Old Apr 16, 2020 | 08:53 AM
spartanga's Avatar
Default Engine noise identification
My 2002 AP1 has 205k miles. Just replaced TCT with billman TCT which solved that noise.
However, now when warm (not when cold) I get the attached noise file. Fairly loud. Is this valves? Or is this worse? accessory?
Engine pulls strong. It does burn oil. Probably 800 miles a quart especially when revved higher of course.
thanks!
File Type: mp3
Old Apr 16, 2020 | 10:59 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
Very low frequency, valve adjustment is first thing to check.
Old Apr 16, 2020 | 11:44 AM
spartanga's Avatar
Thanks. I can do that myself...used to adjust the valves on my CBR900RR which was more difficult as you had to removed the cams to replaces shims under the buckets. At least these are just screw type. I still have the thickness gauges.
Jim
Old Apr 16, 2020 | 01:13 PM
Billman250's Avatar
Top Answer: 1
Old Apr 16, 2020 | 04:03 PM
spartanga's Avatar
awesome! I had a 1993
Old Apr 16, 2020 | 04:56 PM
windhund116's Avatar
Jim
You know, those shims maybe a pain... but they're quite accurate.
Kyle
Dec 28, 2018 05:01 PM
First_honda
Jul 11, 2018 01:18 PM
K_iju
Jul 4, 2018 05:06 AM
yamaha6611
May 23, 2017 10:56 AM
