Engine Problems
Old Oct 28, 2009 | 05:20 AM
tugsta's Avatar
Default Engine Problems
Hi All,
Im having an issue with my MY03 s2k.
For the past 2 weeks or so my car has been blowing out white smoke. THis is after the car is fully warmed up and during mid day. I thought ok must be a piston ring.
Did a compression test and Cylinder #4 had low compression.
I dont know what to do, should i pull the engine apart and rebuild? what if i just rebuild the cylinder thats having the problem? can someone please help advise me.
im a bit anxious and do not know where to begin.
Engine has 35,000km. no cel code.
looking for advice.
Thanks.
Old Oct 28, 2009 | 07:26 AM
spectacle's Avatar
Pull the engine and rebuild all 4 cyls. Pulling the motor is the hard part, no sense in doing that for only one cylinder.
Old Oct 28, 2009 | 08:52 AM
Fredster's Avatar
if you lost compression, and white smoke is coming out, your head gasket may be done. which in terms usually creates a leak of coolant into your cylinder, which is bad. GL.
Old Oct 28, 2009 | 11:52 AM
lewiS2K's Avatar
Are you still running a cat?
Does the white smoke smell sweet? kinda like coolant?
Are you low on coolant?
how low was the compression in cyl 4?
Old Oct 28, 2009 | 12:02 PM
bpaspi's Avatar
First check all the easier possibilities. Pulling the engine can be done if it's neccessary.
Check your coolant level in the radiator - not in the coolant overflow! White smoke indicates water steam. Could be a head gasket or also a crack in the cylinder head itself.
If the compression wasn't low on #4 I would have thought of a blown intake manifold gasket. The water inlet is near by the intake runner of cyl.4
Old Oct 29, 2009 | 04:24 AM
tugsta's Avatar
thanks for the above input from all.
I did a compression test and these were the results;
Cyl #1 - 11%
Cyl #2 - 11.5%
Cyl #3 - 10%
Cyl #4 - 9%
what other tests should i do before i pull the engine?
Old Oct 29, 2009 | 05:56 AM
tugsta's Avatar
Originally Posted by lewiS2K,Oct 29 2009, 03:52 AM
Are you still running a cat? - nope
Does the white smoke smell sweet? kinda like coolant? - didnt manage to actaully smell the smoke as i was inside my car at the time
Are you low on coolant? yes coolant seems to be decreasing after topping up a few times. Smoking has progressively gotten worst
how low was the compression in cyl 4? - please see my previous reply.
Please see my answers to your questions in your quote.
Old Oct 29, 2009 | 09:28 AM
bpaspi's Avatar
tugsta, you've talked about a low compression on #4. But it looks like all cylinders are nearly equal. BTW, how should I read your table? Minus 9% from the regular value? Or only 9% compression at all??
regards
Bernd
Old Oct 29, 2009 | 03:40 PM
Fusiondynamics's Avatar
Could be coolant leaking into your engine.
Old Oct 30, 2009 | 10:08 PM
Kirpich's Avatar
If it's white, it's coolant.
If it's bluish, it's oil.
If it's black/gray, it's fuel.
