engine problems AP1
Old Sep 19, 2010 | 08:20 PM
noxcus's Avatar
Default engine problems AP1
Hey guys, just this morning started up the s2k and this really bad smell comes out of the exhaust more like rotten eggs, but the exhaust color is normal no change there, as i accelarate the car vibrates and the revs on idle go up and down a little, i had a look on google for what these symptoms are its reffering to coilpack problems, is this true any help would be aprreciated.
Old Sep 19, 2010 | 08:28 PM
imnida's Avatar
ehhh, rotten eggs? well, think of it as sulfur burning. Check fuel injectors, or even your catalyc converter.
Do you use injector cleaning stuff?
Also, check to see if your leaking any fluids by your differential or gearbox (tranny).
You could be burning exess fluid drips of you changed the trans fluid or diff fluid lately.
But this is my .02. Not sure if it will help you.
Old Sep 19, 2010 | 08:36 PM
2003AP1's Avatar
Rotten eggs usually means bad cat, but I find it hard to go bad overnight, any CEL?
Old Sep 19, 2010 | 08:38 PM
noxcus's Avatar
umm what do you mean by CEL?
305AP1's Avatar
If an automobile battery is in normal condition, there should be very little smell from it. The one smell that you should be aware of is the smell of rotten eggs, which indicates severe and dangerous problems with the battery. Once a battery begins to smell like rotten eggs, it cannot be saved, but must be immediately replaced. Please be aware that rotten-egg batteries can explode. Rotten-egg batteries are frequently much hotter than normal batteries would be, and the hot rotten-egg batteries are the most dangerous. The most common cause of rotten-egg batteries is an alternator which constantly overcharges, so the alternator should usually be replaced along with the battery.
Old Sep 19, 2010 | 09:38 PM
noxcus's Avatar
would the rotten egg battery affect how the car go's, because the seems to be struggling as i accelerate vibrating like a sti exhaust, man that egg smell is realllllyyy badd!!!!!
Old Sep 19, 2010 | 09:43 PM
imnida's Avatar
CEL, check engine light
probably help us a little if you let us know more about your S.
Year and mods (if any)
What you have last done to it in terms of maintenence etc
Old Sep 19, 2010 | 09:51 PM
noxcus's Avatar
it sits on 130000 kms, 99 model, i regularly service it, and spark plugs are 20000km's old and they last up to 80000km's apparently, no mods done to the car its full stock, its not leaking any oils either, just struggling to go and has that bad smell, gears change as normal, i called honda they said it could be the cat converter maybe rubber issues but dont know for certain.
Old Sep 19, 2010 | 09:57 PM
imnida's Avatar
[QUOTE=noxcus,Sep 19 2010, 09:51 PM] it sits on 130000 kms, 99
Old Sep 19, 2010 | 10:07 PM
2003AP1's Avatar
I am assuming your running super rich..or your catalytic converter is shot. In either case you would have a check engine light, a little yellow symbol on your dash after you start your car or possibly while driving. Do you have one on, either steady on or flashing when driving?
stwokayyy
Apr 15, 2020 11:21 PM
ap01s2kj
Aug 12, 2013 07:16 AM
Strife350z
Jan 25, 2005 04:48 PM
blue2k2s2k
Jun 24, 2003 06:21 AM
