Engine Rattle at Idle
Old Feb 23, 2005 | 09:29 AM
RACER's Avatar
Originally Posted by BlueSTwoK' date='Feb 23 2005, 10:13 AM
I also asked them if they checked the oil level since my 3K miles were up at this point! They said it was a quart and a half low.
I don't know if you are aware, but the owners manual says to check the oil level at every fillup. The oil level should be checked at least every other fillup or 300-400 miles at least. This car is a high compression, high reving sports car that needs a little bit of TLC
BTW, your lucky it wasn't like 2 1/2 or 3 1/2 quarts down.
Old Feb 23, 2005 | 09:39 AM
mxt_77's Avatar
Originally Posted by BlueSTwoK' date='Feb 23 2005, 01:13 PM
And since our valves are self adjusting they said my car wouldn't need it until about 105K miles.
Self adjusting valves?
Old Feb 23, 2005 | 09:46 AM
RACER's Avatar
Old Feb 23, 2005 | 10:44 AM
S2KenC's Avatar
You mean you didn't pay the extra $1000 to have this option?
Old Feb 23, 2005 | 02:20 PM
BlueSTwoK's Avatar
That's what they said....That our valves self adjust! I am just quoting what the dealership said when she looked it up on the computer. Don't take my word for it. I wasn't aware of it!
Old Feb 23, 2005 | 02:25 PM
PilotKD's Avatar
No, they are not self adjusting. We do not have hydraulic lifters. Those are self adjusting to an extent.
Could it be a heat shield?
Old Feb 23, 2005 | 02:44 PM
slalom44's Avatar
Top Answer: 1
If a small piece of debris breaks loose from the engine, it could rattle around at the front of your catalytic converter. It would likely not rattle around at higher RPMs because the pressure would force the object to stay in one place. This is unlikely, but I've seen it happen several times on other vehicles.
The substrate in our converters is metal foil, and not ceramic. If this is your problem, over time you will notice some performance loss due to lack of gas flow.
You could ask Honda to pay particular attention to noises from the converter. If this turns out to be the problem, I recommend getting them to replace it under warranty.
Old Feb 23, 2005 | 08:27 PM
reds2's Avatar
Did you check your strikers inside the car for the top. Sometimes mine rattle like crazy and I thought it was coming from the engine bay.
Old Feb 23, 2005 | 10:18 PM
d.h's Avatar
d.h
Well, I have a rattle problem of my own, but it's difference from yours. First off, you know how the car shake when you're coming to a stop and forgot the put it in neutral(right before it stalls). Well, it happen to me when i'm coming a stop, and all of the sudden, the car vibrates. I thought, crap, I forgot to put it in neutral. I quickly put my hand on the shifter,....and then wait...it is on neutral. It only vibrate like it's about to stall, but it didn't stall. Happen to me about 3 times now, so it's something rare. Any ideas?
Old Feb 24, 2005 | 04:16 PM
figurethisout's Avatar
Blue,
I wrote a post today 2/24/05 on what happend to my valves, I never had a rattle sound, The whole engine block would shake like a cartoon. Is your CEL blinking? Are you getting codes at all? Misfire?
Another thing is that my car would do is idle at different points, sometimes it would idle at 1-2 bars... sometimes it would at 4-5..
I was also a quart low on oil but even after filling it up to H, It did not change the issue..
Xene
May 1, 2012 01:41 PM
TopGear
Sep 16, 2011 04:34 PM
Pinchy
25
Feb 11, 2009 02:08 PM
eshar4ever
Aug 1, 2008 10:53 PM
