Engine RPM suddenly drops when held in VTEC
Originally Posted by Funat9' date='Jan 28 2009, 10:45 AM
wow south africa huh??? I take it you don't have autozone there...
Originally Posted by Gigdy' date='Jan 28 2009, 12:29 PM
Its probably your car dropping out of VTEC. In wich case it is normal.
Originally Posted by xrapidx' date='Jan 29 2009, 03:05 AM
Definitely not that - unless it can randomly happen above 7000rpm...
Originally Posted by Gigdy' date='Jan 29 2009, 06:08 AM
Yes your car can drop out of vtec above 7000 rpm. And the instance you described sounds like the type of time it would happen.
Also - why would it cause a CEL?
I had the same thing happen to me just once. Holding about 6k in preparation to pass on a slight uphill grade, the revs dropped all the way down to idle and very quickly, as if I had let off the gas and pushed in the clutch, even though I was still on the gas and nowhere near the clutch. No CEL for me. I clutched and put the car out and into gear and continued on my way without any further issues. Scared the cr@p out of me.
Originally Posted by xrapidx' date='Jan 29 2009, 10:11 AM
Why would that happen?
very wierd indeed!
