Engine Temperature at 2bar ?
Normal behavior for the car is to reach 3 bar within 7 minutes in ambient temperature between 20F - 100F. Higher ambient (say 90F) will make the car reach 3 bar sooner within 3 minutes of cold start (morning).
Recently, the car stay at 1 bar for aboout 5 minutes after start and then stay at 2 bar for very long time (15 minutes) before reaching 3 bar. At times, during normal driving the temp bar will drop back to 2. When this happens, I can still rev it up to 9K without limiter kicking in.
What is going on
What is going on
Originally Posted by Sideways,Jan 20 2006, 08:09 AM
Sounds perfectly normal to me. If the ambient air is cool enough the engine temp can drop a little.
Originally Posted by dangarza,Jan 20 2006, 01:44 PM
It can cool enough sure, but not enough to drop to 2 bars. I have neverseen my car do that.
Cold ambient temp can slow down the time it takes to get to 3 bars, but can NEVER be cold enough to drop engine temp if the thermostat is working properly. If not the thermostat, the culprit is most likely a lose connection as the other guy suggested.
Not for sure if this will help you out but I have the apexi I-moni that plugs into the obd2 port, well this device displays water temp directly from the ecu. When ever the water temp reaches 160 degrees or above 3 bars, anything under that registers 2 bars. I have the mugen thermostat and a majority of city driving I see 3 bars with a temp around 195 to 170, on the highway though, granted it's pretty cool here in Kansas right now I register just under 160 and have 2 bars showing at all times. Hope that helps a little.
