Engine ticking noise need help! video inside
Hi guys,
I have had an annoying engine ticking noise for a long time, maybe more than a year and 10k miles. During the time I have had this noise, I have tried several times to trouble shot this noise but had no luck.
So this week I have decided I have to figure this out. I tried valve adjustment (engine sit overnight), sand blasting TCT fix, pulled all the heat shield from the manifold, pulled the aux belt and run the engine, pull injector plug one at a time to listen. All of these didn't indicate where the problem is from.
The ticking noise seems to come from the exhaust side of the engine, and is very noticeable when I'm standing on either side of the car with hood closed. I did a lot of research and only found one post have almost the same ticking noise as mine, and looks like that member didn't end up figuring it out.
This is the post that had similar noise as mine: The post
Could this noise come from the exhaust manifold? Btw the car is close to all stock except a test pipe. I'm going to take some video and upload it later.
P.s. When I pulled the oil pan I didn't see any metal pieces from a bearings or anything, but I did fine a small tan/orange piece that was 1mm x2 mm; I have pondered what it could be... I can only think of one thing, the timing chain guides.
Originally Posted by shing' timestamp='1399496847' post='23149101
here are the videos:
[media]http://youtu.be/jCldHGjHuAE[/media]
Here is a video of the engine bay:
[media]http://youtu.be/H-n_-YrGcGU[/media]
Any input is appreciated!
MY2002. I bought this car about 2 years ago with 55000 miles and car now has 71000 miles. I have never run low on oil on this car but have no idea of the previous history of the car. I can hear it fairly clearly when in a resonated environment (underground garage, by walls). The frequency of the noise is relative to engine speed but the noise doesn't change its tone or sound level with engine speed.
I'm not too worried about the noise. Just want to know what is this noise all about. Sometimes when I have a very busy schedule I would forget it but then once in a while when I'm sort of free then I would start all over again to try to figure it out. Driving me crazy
Combination of valve-train and injector noise and very mild piston slap. Sorry to say, but after 70k ish miles your cylinders are no longer round, don't worry the motor still has PLENTY of life left in it and it's a "normal" noise. The noise will always be present in these cars(AP1's), it's a byproduct of how the engines were assembled. Just keep up your maintenance and drive her.
Can you quickly describe what noise is the "piston slap" noise?
Mine sounds similar. Also a 2002, 92k miles. I thought something was up but others have said its not TCT and is a "normal" sound. The good thing is I can only really hear it when driving when the top is up, A/C off, and stereo off...which is basically never.
