engine wont start
Old Apr 24, 2009 | 12:14 PM
drhess06259's Avatar
Default engine wont start
ok so last fall i overheated the motor,(coolant went into water) and warped the head/ blew the headgasket, at the time i was supercharged sold the supercharger to get the new head, put the motor back together, and ended up getting a turbo kit. so now that everything is back together it doesn't start. I did a compression test got 100-100-100-70? this was a cold motor as i can't get it started to warm it up. I also had to get used coils as i slightly melted one in the overheat process. so i am not 100% that they work either. there is fuel on the plugs. any help or sugestions would be appreciated, its starting to get nice out and i would like to drive my s soon.
Old Apr 24, 2009 | 01:10 PM
crave13k's Avatar
check your timing.
Old Apr 24, 2009 | 01:44 PM
was dead on, when i adjusted the valves, so i also reloacted the battery to the trunk i think that could be the problem. I added another ground to the battery, and it seems to be better, almost starts then seems like it is dieing out. i have a yellow top btw.
Old Apr 24, 2009 | 03:24 PM
Slows2k's Avatar
Double posted in FI. This one is closed, Please continue the other thread.
ttang
Feb 15, 2010 03:16 PM
drhess06259
Apr 27, 2009 06:53 AM
howardtan
May 31, 2008 05:48 PM
news2kroller
Jan 28, 2008 06:17 PM
