EPS light is on
Old Aug 20, 2009 | 08:39 AM
sbrodacz's Avatar
Banned
Default EPS light is on
I relocated my fuse box and my eps light is on. What should I do to trouble shoot the issue? Everything looks good from what i can see.
Old Aug 20, 2009 | 08:44 AM
mikegarrison's Avatar
Try driving around the block and seeing if it turns off. Seriously ... EPS needs a valid speed signal, so that can sometimes be the issue.
Other than that, I guess pull the code and see what it says.
Old Aug 20, 2009 | 09:35 AM
Fast Jack's Avatar
Be careful driving,as the power assist maybe turned off or restricted.If the light stays on after the car is started.
Old Aug 20, 2009 | 10:28 AM
sbrodacz's Avatar
Banned
I fixed. Pretty stupid mistake. I plugged the harness's in the wrong sides. For anyone who is doing a fuse box relocation make sure you put the plugs on the eps on the right side
Other then that my abs light is on. It came on once I put my oem wheels and tires back on... Before the relocation.
Old Aug 20, 2009 | 10:33 AM
Fast Jack's Avatar
Success ABS now...hmmm
Old Aug 20, 2009 | 10:42 AM
sbrodacz's Avatar
Banned
your guess is as good as mine.
Old Aug 20, 2009 | 11:14 AM
Crisgo's Avatar
Maybe you "hit" the abs sensor when you were reinstall you oem wheels. Flash that code to see what it comes up with
Old Aug 20, 2009 | 11:39 AM
Fast Jack's Avatar
Yep,broken,loose,dirty,or stretched wire or connection.Search dat one.
Old Aug 20, 2009 | 03:36 PM
sbrodacz's Avatar
Banned
Where is the connectors? I'm running an ems can't pull the code.
Old Aug 20, 2009 | 06:31 PM
sbrodacz's Avatar
Banned
I'd like to check the connectors first.
