Exhaust Wrap question?
Originally posted by Slows2k
Most likely the rear section was wrapped because it runs very close to the fuel tank. Iv'e seen some very poor fitting exhausts on Civics, with the pipe resting on the fuel tank.
*First Post*
s2kevolution -
the wrap
on the hatchback it was probably useless like you stated ... if he watnted to relieve underhood temps, he could have saved $90 on the wrap, and bought a $0.20 pack of washers, and shimmed his hood bolts so the back of the hood sits higher up, and then took out the piece of rubber seal that is on the back of the engine bay, this would create a draft form the bumper inlet out the top rear of the hood where all the hot air is, kind of like a cowl hood works, and it would reduce temps quite a bit .... (lil JDM drifter trick i heard about a long time ago)
But ... if his car was turboed, it would be beneficial to wrap the downpipe, or header to increase exhaust temps farther away from the turbo outlet, because hotter air moves more quickly, than cold air would. Whitch if you know the dynamics of forced induction, the lower the pressure after the turbo, the faster it will spool, and will be more efficient.
But probably not necessary to have the entire exhaust wrapped. that guy sounds like he wanted to waste some money.
s2kevolution -
the wrap
i wrapped my entire exhaust, its 3" pretty much a straight shot from the header back, it's a massive drop in sound compared to unwrapped, removes a lot of the drone, other than that i dint use it for anything heat wise
cost me 25$ for a ebay 50 foot roll on black
also, shouldn't knock other peoples cars, esp when your rocking ricer 101 cross-drilled/slotted rotors
Keeping the heat inside the header/exhaust helps exhaust scavenging and makes more power, If its wraped all the way to the muffler he is probably trying to reduse in cabin exhaust noise(which will be alot more prevalent in a hatchback since there is open cabin over the entire exhaust and the muffler is all the way in the back of the car). This will work to a certin degree. if your useing a Ti header then I wouldnt suggest wraping it cause it will crack, but if your using a quality stainless header/exhaust then it most likely will not crack from heat. My Hotshot header on my SR20 sentra has been DEI wraped and silicone coated for about 40,000 miles now with no problems.
WTF??? cross-drilled/slotted rotors is rice???? I just put put some on my baby about a month ago. I had some brake squeaks when I had the stock rotors and now that I put the ricer rotors the squeaks went away... oh well.
