F22C in AP1
Old Sep 30, 2007 | 02:32 AM
yosephs2k's Avatar
Default F22C in AP1
im planning on dropping an 05 AP2 engine in a MY00 S2000.
i would appreciate it if any1 could give me some tips, things to watch out for, advice.
any extra parts i might need from the AP2. (other than the transmission)?
would the ECU work properly? any1 tried this be4? CELs? any problems?
i appreciate any help.
thanx in advance.
-Joe
Old Sep 30, 2007 | 06:55 AM
s2k rookie's Avatar
I have a F22c bored to a 2.4l displacement in my car but i cant help you cuz i didnt do the swap. I just wanted to show off. good luck.
Old Sep 30, 2007 | 07:20 AM
yosephs2k's Avatar
Old Sep 30, 2007 | 09:15 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
Very slight modification to the fuel line where it connects to the rail, if you use the AP2 rail.
That is IT. Should take you less than a minute to adjust the fuel line to fit.
Old Oct 28, 2009 | 06:59 PM
maluch's Avatar
the ap2 engine doesn't seem to have a timing sensor on the intake camshaft...does that throw a code when using an ap1 ecu??
Old Oct 28, 2009 | 09:32 PM
Ralleh's Avatar
Hahaha!
Enjoy the tq, OP.
Old Oct 29, 2009 | 04:02 AM
S2kRally's Avatar
id imagine you would need the correct ecu for the engine, i doubt an AP1 ecu would run the AP2 engine properly...
Old Oct 29, 2009 | 04:11 AM
spectacle's Avatar
No, it actually works pretty well from what I hear.
Old Oct 29, 2009 | 07:01 AM
TelosHedge's Avatar
its not hard. as bill said, the fuel rail is slightly different. i just re-used my ap1 rail for simplicity's sake.
most other parts are interchangable. i did my swap without pulling my a/c compressor - i just unbolted it from the motor and left it in there. when i went to put everything back together i tried to use my AP1 starter, but it did not bolt up correctly. not a big deal, but something to note.
as far as the ECU goes, it should work just fine - though i don't recommend revving your ap2 motor to 9 grand. TDC sensors for the cams work - i'm not sure what maluch had troubles with.
while you're swapping be sure to re-use your ap1 flywheel - it's much lighter than the ap2 one!
Old Oct 29, 2009 | 01:16 PM
00wreckedS's Avatar
^^ exactly like TelosHedge stated. I did the exact same thing, minus A/C as I removed it when did the f22c swap. I however used the f22 fuel rail, very easy to adapt. I run a 2000MY ecu with absolutely no problems, just don't over ev, cuz it won't stop you And yes re-use AP1 flywheel, check to see wear and tear, I opted to resurface mine when swapping engine just for peace of mind.
