F22C Build
Old Sep 11, 2012 | 08:49 AM
TODAEG9's Avatar
Default F22C Build
Hi everyone,
i am planning to have a rebuild my JDM 2004 AP1 Facelifted F20C,
From the beginning i decided to buy Mahle FRM piston 12.5CR 87.25mm with Carillo Pro A F22 Rod,
but after a discussion with my local machine shop, seems they dont have any confidence even i gave him the guideline for bored and honed block from original manual.
So now i am started to think about keep my JDM AP1 piston to avoid any pison failure if they are good enough to re used, just change new rings from 06+ AP2, seems they are a better design isnt it?
And swap in the Balanced and Micropolished F22C Crannk and F22C original rod, since i used stock piston with 22.7mm pin diameter so this is a direct bolt on without any machine work, and they are floating rod and good enough already for 250~ whp. Just a little bit heavier than Carrillo Pro A.
I had do a research for AP2 Rod + Crank plus JDM F20C piston = 12.7 CR ! Am i right? seems its a beast for All Motor setup and even higher CR than Mahle piston.
Finally i found that is no point to buy after market parts, and i heard S2000 OEM piston is forged already.
Any comment ? anyone tried this combo before?
Thanks!
donaldmejr
Apr 23, 2014 07:31 PM
TODAEG9
Sep 17, 2012 11:40 AM
ILOVEMYAP2
Oct 9, 2009 06:31 AM
lookinco
Jul 29, 2009 12:53 PM
CarbonYellowJ's
Apr 11, 2008 06:54 AM
