First problem with the car...
Old May 9, 2009 | 05:36 AM
foxy_s2k's Avatar
Default First problem with the car...
No CEL, no other symptoms. 2001 with about 61000 miles on it.
When I pull away from a junction, without gunning it, just gently letting the clutch out and applying gas, it wants to stall. I immediately pop the clutch and rev it, and then it's fine until the next time. This has been happening for a few days.
Today, for the first time, it had what felt like a misfire. A total loss of power, lmost like fuel cutoff for a few miliseconds. Again, pop clutch, rev, and it's ok for a couple more miles, then it'll do it again. If I drive it really relaxed, always under 4000rpm, no problems are apparent. When I go through 4-5500 rpm, accelerating or decelerating, it sometimes misses a beat. No mods at all.
Suggestions?
Old May 9, 2009 | 11:31 AM
negcamber's Avatar
Sounds like a bad MAP. You can try the MAP whack or unplug/replug and use a zip tie to help hold it in place or you can buy a new MAP which will have the zip tie included.
Old May 10, 2009 | 12:18 AM
foxy_s2k's Avatar
Thanks negcamber, I'll try the MAP whack and ECU reset and see what happens.
Old May 10, 2009 | 01:50 AM
foxy_s2k's Avatar
Map whack and ECU reset worked. So far so good.
Map whack and ECU reset article... https://www.s2ki.com/forums/index.php?act=S...0#entry12038827
S2Kmiadade
Sep 4, 2011 01:35 AM
lowandsmooth
Aug 26, 2009 06:58 PM
Sub_01
Sep 19, 2008 07:46 AM
Dewain27
Oct 12, 2004 07:57 PM
