Fluid change intervals...
Old Aug 16, 2004 | 03:09 PM
r_duff's Avatar
Default Fluid change intervals...
Hey, dont have my manual here on me at work, and cant find a good thread.
how often do you guys change your fluids?
i.e.:
Oil, tranny, diff?
Hell, lets throw in air filer and micro filter too.
Old Aug 16, 2004 | 03:25 PM
xviper's Avatar
First, I don't go by the book. For some intervals, it's just too long in the book.
engine oil and filter - every 3000 miles (and that's only because that translates to 5000 KM for me and it's easier to remember).
tranny - annually because it's easy for me to do at home but if your tranny is not giving you any issues, then every couple years is fine.
diff - also annually, but the original fluid should be dumped withing the first few thousand miles.
air and micron filters - should be checked annually, changed if required. I have a re-useable JR and I clean it annually.
Don't forget brake and clutch fluid. With average mileage, I do these every couple of years.
Note that if you track the car or drive it really hard most of the time, most of these changes should be done more often.
Go to the top of "Under the Hood" and check out the stickies threads on oil and "How To's" about doing this stuff.
Old Aug 16, 2004 | 03:40 PM
r_duff's Avatar
awesome viper. thanks alot.
Old Aug 16, 2004 | 07:45 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
my intervals for all my S customers....
First dif....3k (it will be quite dirty) 10k thereafter
Trans...15k
engine oil...3k
first clutch...3k....10k thereafter (helps alot with clutch disengagement and gear grinds/shifting)
Brake fluid...2years
Old Aug 17, 2004 | 07:03 AM
Mike in Atlanta's Avatar
Do you all recommend 3000 mile engine oil intervals even when using synthetic oil?
jwkim
Feb 8, 2011 06:52 PM
The Twanksta
Jul 28, 2007 11:11 AM
Tx_Phantom
Aug 15, 2006 10:16 AM
Ajjra
Nov 17, 2003 08:07 AM
allkingz
Jul 17, 2003 12:37 PM
