Fluid flush
Old Apr 3, 2014 | 04:47 AM
kwakhead's Avatar
Default Fluid flush
It's time to do a complete fluid change on my car.
I bought it in June of last year. It's an '05 with 42000 miles.
My question is how much brake fluid do I need to buy to replace the brake & clutch fluid? I've found the capacities for everything else, motor oil, diff, Trans & coolant. Just not sure about brake & clutch.
Old Apr 3, 2014 | 05:06 AM
spets's Avatar
Two liters of brake fluid should be enough.. you'll probably go through a liter just for the brake fluid, and then you can use a quarter/half a liter on the clutch. two liters should give you some extra to spare.
Old Apr 3, 2014 | 07:44 AM
dwight's Avatar
1 liter is definitely more than enough to flush the brake lines. I used Billman's siphon, clean and refill the reservoir method for the clutch. That used very little fluid.
Old Apr 3, 2014 | 08:53 AM
iamxpl's Avatar
one can of ATE should suffice.
TheLast13
Feb 11, 2011 04:36 PM
S2KNJ
Jun 5, 2008 12:18 PM
Tanqueray
Jun 8, 2001 01:53 PM
