Flywheels and engine RPMS
Originally posted by dhess
Yeah. so no "Granny shifting!, not double clutching like you should."
Your flywheel has absolutely no impact on the relationship between engine rpms and vehicle speed! That is purely a matter of gearing and tire size.
A lightened flywheel will allow you to rev your engine more quickly for shifts and such.
I spent quite a few hours creating a gear calculator web application so you can all tinker with the effects of changing variables related to gearing and the relationship between engine rpm and vehicle speed. Click here to go to my gear calculator program. S2000 values are built-in, just click on "Use S2000 Ratios".
HTH.
HTH.
Originally posted by ChrisD
I've personally been at 168 in 6th at around 7000 rpms... Would seem like I have about 20 more mph to work with.
