Fob Failures
Did a search but didn't see my problem. On several occasions my keyfob will stop working. It seems to randomly fail about once a week (it's a dd). The light on the fob lights up, but nothing happens. Range isn't an issue and I can stand right next to the car and still get nothing (trunk release, lock and unlock fail to work).
Then, if I drive the car and get out, the keyfob will start working again. Am I missing something?
Originally Posted by Slows2k,Jun 19 2007, 08:54 PM
Step 1, Replace the battery.
If you want better range hold the remote against your chin. (trust me it works)
If it still messes up the remote would be under warranty on your 06
Your local dealer stocks them. This is the only thing they stock that fits the S2000
The chin thing works. Why is becasue the remote will use your body as an attenna. This works for car alarms too.
Chin can help sometimes, usually more to do with range issues when this works.
If it is cold, try warming the fob up (eg hold it under your armpit for a min or two).
If the light doesn't light up, try hitting the fob against your other hand. Sometimes my car remote needs a little percussive maintenance.
My fob's red light will light up. But the car will not unlock. I have to put they key in the ignition turn to the IGN position then off again in order for the keyless to work again....or just wait about 5 mins.
Same problem here.... it happens randomly and only happened twice in two years so i'm not concerned but it could confused by another signal and resets itself when you start the car..
